FT400 Single Turbo System
The FT400 is an intercooled turbo system that creates 0.9bar/13psi and produces 400 hp and 380 ft/lbs of gut wrenching torque. More boost means more heat. Keeping to a side mount intercooler, cools the air charge without reducing the critical cooling capacity of your radiator. The cast short runner intake manifold shortens the air path to your motor for optimized throttle response. With form fitted Silicon hoses, no chopping or massaging will be required at time of install.
FT400 includes:
* HGP R30 Garrett Ball Bearing based hybrid turbo
* Custom compressor housing
* Integrated recirculation valve
* Custom exhaust housing with integrated wastegate
* Flowbenched Cast exhaust manifold with external Oxygen sensors
* Short Runner Cast Aluminum Intake Manifold
* Side Mount Intercooler with velocity air shrouding
* Stainless Steel Exhaust Manifold Heatshield
* Flow Optimized cast downpipe feed
* 70mm downpipe with integrated flexjoint featuring interlocked liner hose for better flow
* Custom wrapped Silicone piping with stainless steel clamps
* High flow fuel injectors
* Head spacer plate to lower compression to 8.5:1
* Braided Stainless Steel Oil Feed Line
* Oil Return lines
* Water inlet and return lines
* Performance ECU upgrade
Available for:
Mk4 VW R32
Mk1 Audi TT 3.2L
Mk5 VW R32
VW Eos 3.2L
Mk2 Audi TT 3.2L
Audi A3 3.2L
http://www.vagtech.co.uk/index.php?o...d=71&Itemid=56
FT450 Single Turbo System
Imagine parked in your garage, a daily driver that tears off a ¼ mile off in the high 11s while getting 27+ MPG on the highway. FT450 is that package. Producing an inspiring 450 hp and 415 ft/lbs. of torque, this package breathes through dual side mount intercoolers and upgraded high flow cats allowing the turbo to run a healthy 0.96bar/14psi... Whether you play on the race track in your spare time, or just need that electrifying thrust on your commute home, the FT450 will put you into the class of the World's top super cars!
FT450 includes:
* Side Mount Intercooler(s)* with velocity air shrouding
* Oil Return lines
* High Flow Fuel Pump
* High Flow Catalysts
* Race Grade Connecting Rod Bearings
* High Flow Mass Air Flow Sensor
* Mk4 Applications use double side mount intercoolers, Mk5 Applications use single side mount intercoolers
Available for:
Mk4 VW R32
Mk1 Audi TT 3.2L
Mk5 VW R32
VW Eos 3.2L
Mk2 Audi TT 3.2L
Audi A3 3.2L
http://www.vagtech.co.uk/index.php?o...d=73&Itemid=56
FT400 includes:
* Oil Return lines
Available for:
Mk4 VW R32
Mk1 Audi TT 3.2L
Mk5 VW R32
VW Eos 3.2L
Mk2 Audi TT 3.2L
Audi A3 3.2L
FT450 includes:
* Oil Return lines
Available for:
Mk4 VW R32
Mk1 Audi TT 3.2L
Mk5 VW R32
VW Eos 3.2L
Mk2 Audi TT 3.2L
Audi A3 3.2L
