MY2007 is the current estimate, rumour has it that it will produce around 360 HP and 310 lbs/ft which is slightly up on the current model. Redline increased in line with the current RS4 to 8200rpm
I think Audi are seeing how it does in the RS4 first. I'd be miffed if I bought an RS4 then find they stuck the same engine (well almost) in a much cheaper S4
[ QUOTE ]
[/ QUOTE ]
Why would they increase the redline to 8200? The reason the RS4 revs to that level is so that it can produce it's power without the need for forced induction. I doubt the S4's redline will be increased as its power output is only marginally higher than the current model.
Does anyone know if the RS4 will still use hydraulic lifters or have Audi gone to bucket and shims to reach those RPMs?
