Frozen door latch.........
VAGMAN1 Dec 9, 2005
  1. VAGMAN1
    VAGMAN1 Member
    306
    anybody suffered with this in sub zero temps before?
    I open the drivers door - no problem, then when I try to close it the latch doesn't catch on the striker - it's like the latch mechanism is frozen!
  2. starski4578
    starski4578 Member
    150
    The freezing weather had an effect on my drivers door latch and its only just been replaced!! it would open but kind of get stuck on the latch until i pushed it shut again then it would open!? thought it was gona be some more misery and wonga. Hasn't happened again since its a bit milder! phew
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    I have had that too in the past, its a totaly pain - its not like you can drive along holding the door shut!
  4. madvw
    madvw Active Member
    2,489
    hold the door handle up for five seconds. This activates the heated door handle... or it may just be the locks...
    i dont think this works on rear doors though.
  5. Mo-S3
    Mo-S3 Member
    708
    doesnt help when it happens but try to prevent it before hand by lubricating them well with a good quality grease.
  6. Markb
    Markb Active Member
    2,139
    I had this happen on mine last Saturday at 5.00AM just before I went to work.
    I got into the car by opening the door locks from the boot! As I've got no locks on the door handles.
    It didn't help that the battery was flat as well though!
    P.S I've got no heated door locks as mine packed up lasted year got stuck on and flattened the battery. So they got binned!
  7. Khufu
    5,704
    31
    They only help the locks, not the latches. As said, best to make sure they are well greased so no moisture gets in. Its just as bad when the rubber door seal freezes the door shut! Got flamed here a while back here for suggesting using vasaline. It rots condoms so will also eat your door seals /ubbthreads/images/graemlins/smirk.gif
  8. Mo-S3
    Mo-S3 Member
    708
    Mark, im sure i have 1 or maybe 2 heaters for the door locks if you need them. Its the square unit.
    Also have two door latches as well.
  9. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    Cheers for the offer /ubbthreads/images/graemlins/beerchug.gif
    But seeing as though I've got no locks I will be leaving them off anyway.
