Frozen Cab Windows
Discussion in 'Audi S4/A4/A4 Cab (B7 Chassis)' started by Navman911, Dec 20, 2007.
  1. Navman911
    Navman911 Vipor
    Jul 30, 2007
    Maybe I didn't quite think through my decision to buy a cab. Everytime I need to use the car and the windows are frozen, when I close the doors the windows end up resting against the metal supports of the roof!! Slightly concerned I'm going to crack one of the windows at some point!!
    Obviously pouring warm water onto the windows to defrost them (hence allowing them to move up and down that little bit when the doors open and close) is one way of doing it, and when the car's at home I repossess the garage! But what the hell do I do if I've gone out, and I'm coming back to my car at midnight????
    Any solutions much appreciated?!?:jester:
  2. Advert Guest Advertisement
  3. Cupramax
    Cupramax Uber pimp meister
    Jan 19, 2003
    457
    Sounds like somethings out of alignment. Get your dealer to look at it, not had this problem with mine...
  4. RGBArgee
    RGBArgee Guest
    Agree with Cupra max. Never had this in my 3 winters of A4 Cab ownership.:bye:
  5. andyccr
    andyccr 2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 6, 2007
    442
    Never had a problem with mine either. I just had my door repaired by the bodyshop and he was telling me the windows are completely adjustable, so as above I rekon an alignment problem.
  6. timjhoward
    timjhoward Audi Newbie
    Jul 17, 2007
    33
    Had something similar happen to me earlier today. Opened the door and didn't notice if the window did it's usual drop of a few mm. Went to shut the door but it bounced back open, resting on top of the roof rather than having dropped in behind and then closed fully!
    Got round this by putting the window down manually, then as the engine was running (trying to warm it up a bit!) I lent in and put the window up using the switch (and took my hand out quickly) - window disappeared behind the roof and then shut completely - success!
    I guess you could use the 'comfort close' funtion, opening the window (assuming it is not frozen stuck) and then turn the key in the lock to close all windows etc?
    Must admit I hadn't even thought of this eventuality, roll on spring!
