Front wiper motor part number?
spankius Jan 30, 2012
  1. spankius
    spankius New Member
    Anybody know the front wiper motor part number?
    Will the motor from a b7 fit?
  2. ASHIHARA
    ASHIHARA Member
    294
    15
    part no: 8E2 955 119A
    If you need one,i have a new one which i bought it after a bad diagnostic.
  3. pauldazzle
    pauldazzle Well-Known Member
    1,192
    95
    You sure it's the wiper motor that's failed as it's normally the linkage that seizes up. The motor has a safety cut out built in to it to protect it.
  4. JimLoskot
    JimLoskot Member
    161
    what pauldazzle said, common fault with the B^, the linkage siezes up
  5. spankius
    spankius New Member
    Already replaced linkage last year. Got wet in that area again now wipers are permanently on. Changed relay and tried new wiper stalk, still the same. Hoping the wiper park switch in the motor has failed./
  6. pauldazzle
    1,192
    95
    Sounds like you have a short circuit in the motor.
  7. ASHIHARA
    ASHIHARA Member
    294
    15
    I have it the same problem,and i thought is wiper motor fault,this is the reason because i have one.
    But no,it wasn` the motor,it was the electric control module,because the water come inside of this module,see pics
    The new module cost me 245£ from the stealer :wacko:
  8. pauldazzle
    1,192
    95
    It looks like it's worth spankius having a look at the module before buying a motor then.
  9. quattrojames
    14,060
    583
    Ashihara - what caused your water damage? A leaking ecu cover?
  10. spankius
    spankius New Member
    Is there a way of testing the module?
  11. spankius
    spankius New Member
    Does the new module need programming or is it plug and play
  12. ASHIHARA
    ASHIHARA Member
    294
    15
    Yes,but it was my fault;in the summer time the wiper linkage get blocked and to get it out i had to take the ECU off and i didn`t fit the screw`s back propely.
    You can take him off and check.
    Yes,it need programming; is still working without programming,but doesn`t work properly and throw`s some error code`s.
  13. spankius
    spankius New Member
    Took the module out, it was full of water and even ice. Dried it out, sprayed it with multi lube and everything works.
  14. ASHIHARA
    ASHIHARA Member
    294
    15
    Thanks for helping you :haudrauf:
    spankius likes this.
  15. quattrojames
    14,060
    583
    Manners are few and far between on this forum a lot of the time sadly.
  16. spankius
    spankius New Member
    Sorry.
    Big thanks to ASHIHARA.
    Saved me a lot of time and money. I have spent a couple of weeks and not found the answer anywhere else.
    How do i do a proper thanks, i move the arrow over it and nothing happens.
  17. quattrojames
    14,060
    583
    If you move the mouse over the thanks button the cursor will turn into a finger, so you can click on it. Might not work on a Tapatalk app if thats what you're using.
  18. spankius
    spankius New Member
    Tried it. Could only leave a like?
  19. aabirgti
    aabirgti New Member
    Hi im also having same issue with my wipers its only workin on medium speed and have to remove the fuse to switch it off plus the horn doesnt work n goes off wen it feels like due to the bulkhead drainage being blocked water came through.
    I wanted to know what do you mean by reprogramming the control module?
