Front suspension changing.....
S4_dan Mar 22, 2012
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,751
    165
    I will be doing the front suspension next Wednesday afternoon in the garage at work.
    How long (roughly) does it take to do one side? I am competent at using tools, plus I will have use of windy gun, pit, heat if needed.
    I have bought a cheap kit (don't shout at me! I know, but as long as it gets me through my mot) off ebay (£43) and came with no bolts. But I have been to me bud at VW and got all the nuts/bolts I need. (So glad I didn't have to pay the £61.80 they should of all been!!)
    Does the leg have to off at all? Or is it a case of just removing and replacing the arms? I've done Pugs, Golfs etc with standard wishbones and one lower ball joint etc, Never an individual arm setup.
    Any pointers would be appreciated to save me time next week.
    Test is on Friday.
    The only things I don't have is the TRE's. But had my car over the pit last week and there is no play in the current ones anyway. Only 1 C link and two upper arms were slack but I'm going to replace them all
    TIA,
    Dan
  2. aragorn
    18,608
    871
    having to remove the upright will depend entirely on wether the upper pinch bolt plays ball.
    If you can get it out, then you only need to remove the mounting plate and shock.
    If you cant get it out, you'll probably end up removing it and having to drill it out or similar.
  3. S4_dan
    2,751
    165
    Ah ok. So if the top bolts does come out, I can replace the top, then do the bottom arms not have to remove the hub bolt, disc, caliper etc?
    Cool, so here is to hoping!!
  4. Nessy
    Nessy VW + Audi mad
    958
    93
    As aragorn has already mentioned, those top pinch-bolts can be an absolute swine to remove if they haven't been out before......
    Once they are out though give the new bolt and its path through the strut housing a liberal dose of copper-based grease and you'll never have any aggro again.
    It's a really **** design though IMHO.
