Spacemonkey
So I had the boring 5w bulbs in my front side lights, apparently working fine. After a couple of days of ownership I wanted to fit the Cree leds as I do to all my cars. As I have a few lying around it should be simple, but they are all 501s and the Audi has bayonet fittings as I have factory HIDs. So I check the numbers on the bulbs and order the same fitting. Bit tight but ok. Fit the new ones using bit of paper packing and tape to make a good connection and to make a tight fit in the light as the bulb holders are cracked too. Not convinced by the fit but works fine for a week or two until the right one stops working. Thinking its a dodgy connection I remove it but end up probably damaging the led so fit standard bulb instead. Had a quick glow then stopped. It's never worked since. ~I've played with connections as best I can but no help at all and last night the bulb warning kept going off instead of constant like before. A couple of times the left warning joined in nad last week the warning for left hid leveller flashed on for a minute or two...
Any suggestions? And yes, I do now know the bulb is the wrong sort as the previous owner fitted 180 bayonets instead of the correct offset lug bulbs which I have now ordered, but the old bulbs still worked they just cracked the housing..
