Front seats
mattyboyc Sep 18, 2009
  1. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,893
    185
    :bye:Hi all, any tips on removing the plastic pannel on the back of the front seats, i presume they are clipped in but don't want to damage anything.
    Thanks in advance
    Matty
  2. NHN
    29,295
    1,701
    Based on my previous dealings with few audi seats, try to start from the top edge & get fingers behind slowly & I mean slowly prizing the back of so gives small gap & then if same as mine there are some clips at the top that need to be either popped of or moved to the side to release the back cover thus then lifts of as usually the bottom has some locating hooks that hook over the seat chassis at bottom, take care & patients & not to forceful, torch helps.
    I will try & check elsa for precise guide, but in meantime try as above
    Ok checked elsawin & it is the same as previous ones I've worked on as above, also & adding to above the back cover has some retaining clips at bottom that go under seat, these can be disconnected aswell but should be able to do as above without removing these at 1st, but hey try it anyway & also the sides of the back cover might be hooked over the seat chassis aswell, should all be obvious once you start tbh.
  3. mattyboyc
    1,893
    185
    Thanks for that, i'll give it a try, plenty of paitence eh!!
  4. paul20v
    paul20v Audi fanatic
    1,113
    If you have sports seats the backs just pull off ,
    there on clips but be nice to them .
  5. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    15
    Sports seats back covers pull off from the top via sprung metal clips.
    Be gentle cause being too rough can break the slotted plastic retainer holding the metal sprung clips to the seat back.
    With the 3(?) top clips disengaged the bottom should slide up.
