front screen washer jet adjustment??
Chadders Nov 2, 2012
  1. Chadders
    Chadders Member
    157
    Can anyone tell me how to adjust the washer jets for the windscreen. I know it's a case of fine adjustment with a pin but how on earth do you get to them!! I did a search but didn't come up with anything
  2. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    Hang from a door frame with about 100KG's of weight strapped to your body and stretch them arms.
  3. Chadders
    Chadders Member
    157
    Lol I knew there had to be an easy way
  4. tedward
    tedward Member
    166
    They are a piece of cake to click out of the bonnet and then you can see the jets clearley.
    Just push them downwards slightly towards the Windscreen and pull the top out and pull away from the bonnet. ( done with bonnet up and from under the bonnet over engine)
    Dont pull them to far out as they have washer pipe and heating wires attached, but there is enough slack wire to turn them and see h jets.
  5. Brodster
    3,548
    883
    I think he's having problems actually reaching the jets.
  6. tedward
    tedward Member
    166
    Which is why I just explained how to remove them for easier access. They are hard to reach still fitted to the bonnet.
  7. Chadders
    Chadders Member
    157
    cheers for the reply I'll have a go at removing them I guess the only issue then is getting the jet in the right place and going back and forth fitting and popping them in and out. At the mo they are just a bit to low although with all the rain might not be worth it
