Front mount cooler and bumper mods
Oranoco Jul 31, 2011
  1. Oranoco
    Oranoco Well-Known Member
    3,957
    404
    Busy day yesterday, finally got the De-cat on, which was surpringly easy with the help of a mate.
    Out with the old
    In with the new
    New cooler is bolted in place and is snug against the aircon rad, problem is it looks like I will need to butcher the bumper to refit it.
    How have others done it?
  2. jamie226bhp
    jamie226bhp Member
    468
    Cut almost all the metal away on the back of the bumper where the front mount is and almost all of the bumper itself upto the grills, most of people that fit them dont seem to have the ac rad and dont have to butcher it as much
  3. Oranoco
    3,957
    404
    Sorted :)
    Just need to find some mesh that looks RS4 esq so I can make it look a little less obtrusive
  4. dest
    dest Member
    193
    Im not sure if it would work on an A4, but on an S4 you have to modify the end tanks so the pipes are angled back a bit, then you can fit the bumper with no visible change to it or the grills.
    Mine is being done next week if all goes to plan :D
  5. B5QUAT
    B5QUAT Member
    317
    13
    Which intercooler is that? Looks bigger than the ones I've seen. Do you know the diameter of the pipework?
  6. Oranoco
    3,957
    404
    It's the Toyosports intercooler as found on E-Bay. Can take measurements tomorrow at some point if it'll help. Had to cut a section of metal out the back of the bumper about 250mm long and trim th eplastic back up to the grill edges. It's still.... snug.. shall I say
  7. B5QUAT
    B5QUAT Member
    317
    13
    That'd be cool, thanks.
  8. Oranoco
    3,957
    404
    Right dug the bumpf out and it is claimed to be 450x230x50 but upon actual measuring mine is 453mm x 236mm x 54mm this is largely down to the globby welds.
    HTH
  9. B5QUAT
    B5QUAT Member
    317
    13
    Are you sticking with the original bumper?
    I want to on mine, as I don't like the RS4 bumper option, as it's not an RS4 if you know what I mean?
    It seems such a shame with these big intercoolers that so much of it is covered up by the OEM bumper and reg plate. Suppose you could relocate the reg but then it starts to look very MAX Power. I've seen the longer narrower coolers that seem to fit in the "space exposed to airflow" a bit better but they are only listed as supporting 300-350bhp as they are so small. :(
