front lower wishbones
elz33 Nov 9, 2010
  1. elz33
    elz33 New Member
    hi all, ive got some front lower wishbone bush wear on my 2006 2.0tdi a3 sport and was wondering how hard are the new bushes to fit? or would it be easier just to buy 2 new lower arms instead of replacing the bushes? any help would be greatly appreciated!
    oh and wheres the best place to get the above. . . . any ideas??
    thanks
  2. mike foster
    3,967
    The only place you'll get them is an Audi dealer at £110 each !
    The bonded rubber mountings are £11 each
  3. rickyquicky
    rickyquicky Member
    342
    The front bushes are a pain in the ****!
    I tried taking them out myself and gave up after an hour, afaik you need a press to take them out and refit.
  4. Ash187
    7,495
    744
    i just got quoted £220 fitted for both wishbones and bushes... should be getting it done very soon... and its from an independent garage i use for all my work on the car
  5. sub39h
    sub39h Active Member
    2,502
    If you're fitting new arms fit TT ones. They've got adjustable camber which when set higher is meant to transform the car. They're a straight swap, tho you'll still need A3 bushes to put into them so it doesn't really solve your problem...
  6. RS84
    RS84 R15 - TDI Power
    168
    I went to do the bushes on mine myself recently but had to give up because space on the passenger side was too tight to get in. Gearbox in the way... I've a DSG.
  7. rickyquicky
    rickyquicky Member
    342
    Mines DSG too mate and had the same problem, you need to drop the subframe about 10mm to give you the clearance to slide the bolt out that goes throught the bush...
