Front light washer jets
PaulJC84 Sep 7, 2005
  1. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Hey has anyone fitted headlight washer jets to their cars?
    Its just my car does not have them and i have been looking at a bumper which does.
    Or do you think i should just forget about them and fill them in.
  2. docurley
    4,073
    88
    You will need the whole front bumper plus the water bottle and then figure out how youÂ’re going to wire it all up.
    I was thinking of a relay hooked into the light with a feed off the windscreen pump, as I have to connect my RS4 bumper up.
  3. FezzR
    FezzR Member
    86
    depends how it works
    most of the VAG ones ive seen simply use a larger washer bottle stronger pump and uses the fluid pressure to lift the mechanism and spray very simple
  4. tubtub
    tubtub Member
    160
    Extra weight = slower car + if someone nerfs your front bumper, extra cost to fix it and all for what, cleaner headlamps on those few occasions when they get really flithy between car washes; how often does that happen?
  5. docurley
    4,073
    88
    The washer bottle has the second pump so that it only works when you have the lights on and pull to do your screen.
    I would have thought that current pump is not powerful enough to do both but who knows.
    Plus you would differently need the other pump because you would not be able to connect to anything as the pipe to the bumper jets are very large.
    To mount it all up is easy as has stated the pump pushes the unit up and fires the water.
  6. Danielson
    Danielson Member
    704
    im thinking about losing mine when i go rs4 front, for the smooth look. plus thats extra weight. =)
  7. docurley
    4,073
    88
    Just looked at my old bottle and you can keep it as it as the fitting there just need to drill a small hole for the pump.
