front headlights?
wmd10 May 17, 2005
  1. wmd10
    wmd10 Member
    43
    hi all,
    i have an A4 sline 190bhp.
    is it worth upgrading the bulbs>?
    how do u get into change the bulbs ie sidelights etc?
  2. liam1234
    liam1234 New Member
    Flip the spring covers on the back of the light unit to get access, the small side lights have plastic clips holding the bulb in, these just need to be squeezed together then pulled out of the housing/hole with long nose pliers, unless you have child size hands make sure you wear tight fitting inspection gloves or the top of your hands will be scratched to ****, The bulbs just need to be pulled from the conector.The bigger side lights in the lense have a spring clip that needs to be released then the bulbs can be removed from the conector.
  3. a4sline
    a4sline Member
    185
    Best way to do any bulb changing on B6 is to take out the top 2 bolts, slacken the bottom 2 and take the whole light unit out. Takes 5 minutes tops.
    HTH
  4. The911SC
    The911SC Active Member
    1,032
    .. or hire Jeremy Beadle for the day....! /ubbthreads/images/graemlins/groovy.gif
  5. a4sline
    a4sline Member
    185
    Good idea as the one side is tighter than the other, so different size hands could be an advantage /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif
