Front fogs coming on when lights are switched on.
Maz May 27, 2010
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Hi all, I fixed my brake light switch over the weekend (mini guide due to be uploaded) and whilst it was a straightforward job replacing I think I may have caused a new issue. My front fogs now come on everytime I switch the lights on.
    I plan to remove the the lower dash trim again this wknd to have a looksey.
    Any ideas how to fix or what I might have done to cause this?
    Thanks.
  2. Matt82
    Matt82 Active Member
    2,365
    sounds like youre driving a peugeot or subaru. i heard the fogs on those cars are hardwired to come as the engine starts
  3. Westy
    Westy Well-Known Member
    17,443
    1,103
    Oh no Maz you might as well buy yourself a clio if you're going to drive round with the fogs on :whip:
    I've no idea how changing the brake light swithc would have caused that problem. Surely the fogs are part of a completely different relay!
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    I'd say coincidence.....
  5. Maz
    1,002
    10
    Lol, thats exactly why I must rectify this issue immediatley.
    I'm thinking I may have disturbed something when I unplugged the connections for the light switch behind the lower dash panel.
  6. Westy
    17,443
    1,103
    Yeah sounds like it. Just get it all apart and reconnect and see if the issue goes. Probably just a loose connection somewhere. I have a loose connection to the lights that light the headlights switch up.
  7. Broken Byzan
    13,237
    465
    the switch can go dodgy, might be that, we had it on the TQS, had to dismantle the switch and reset the cam thingy inside
  8. Maz
    1,002
    10
    Thanks, I'll give that a go.
  9. gareth_oau
    gareth_oau Member
    228
    My fogs were always on with the headlights and the mechanic said it was a faulty headlight switch. As its illegal here to drive with fogs on, unless its foggy (which here it virtually never is), I just removed the fuse
