Front Foglights
Caesium May 29, 2005
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    One of my foglights has a broken lens, does anyone know if I can just change the lens or if i have to change the whole unit, and how do I remove it?
  2. scoTTy
    scoTTy Active Member
    1,962
    The plastic grill is held on by 4 catches. Use a screw driver to ease them so they disengage and remove the balck plastic grill. You'll then see the fog light in it's entirety and then it's fairly obvious : There are two bolts which you need to remove and then the unit can be removed. The screw on the opposite site to the two above is for adjustment.
    My Bentley manual only shows it as a complete unit.
  3. a4sline
    a4sline Member
    185
    Sure is a seled unit. There was a couple for sale on ebay the other night for about £18,
    They have appeared on there regularly, just keep an eye out to steal a bargain !!
