Front Fog Lights
Davy Sep 1, 2009
  1. Davy
    Davy New Member
    13
    My B5 has front fogs installed with bulbs but they arn't wired up, the previous owner must of installed them i presume for show. So im looking to get them wired up, is there a certain wire kit available for the front fogs?
    cheers
    Photo of the front, thou its an old shot!
  2. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    Is you car a genuine facelift? If not and it original had the Bosch lights (you'd have a front fog switch on your dash) there wiring should be there already...
  3. aragorn
    18,657
    875
    it has bonnet mounted washer jets, so its not a facelift car, and presumably doesnt have the wiring already.
    Is the button on the dash beside the rear fogs?
    Not sure what would be involved in retro fitting it, but i'm sure it wouldnt be too much work if you got a switch and some loom from a breaker.
  4. Davy
    Davy New Member
    13
    No theres no button on the dash beside the rear fogs. I already checked behind the lights and theres no wiring going to them.
  5. dieselfitter251
    1,120
    Hmmm. I'm guessing it'd be a 'build your own circuit' route you have to take. I'm sure it's been done already.
