Front driveshaft removal?
bazil Feb 20, 2012
  1. bazil
    bazil BOOM BOOM
    135
    Hi all, I need to replace an inner cv gaiter, my question is, are there any nasty surprises in this job or do the shafts come out easy?
    2nd question is what gearbox oil is recomended ?
    The car is a 2000 S3 APY
    Any help or info would be great.
  2. StaceyS3
    StaceyS3 Well-Known Member
    2,489
    473
    Shaft how to is in the stickies ;)
    Not sure about gearbox oil as just got mine from audi :)
  3. <tuffty/>
    20,900
    3,708
    Gearbox oil is 75w90 semi or fully synthetic...
  4. bazil
    bazil BOOM BOOM
    135
    thanks guys, the guide is stickies is a real help, ive ordered 4 CV boot kits from audi just over £120 :sign_omg: they had the outer ones in stock but had to order in the inner ones.
    i just hope the CV is ok as there is not a lot of grease left in it. i tried local parts stockists but nowhere could get me a RH inner boot, must be an odd one due to the transfer box?
  5. <tuffty/>
    20,900
    3,708
    6 speed boxes have larger joints... not many parts places keep anything that fit... last one I tried was more or less the same price as OEM so just used OEM the next time it went...
  6. Westy
    Westy Well-Known Member
    17,443
    1,103
    Does the oil need to be drained and refilled for clutch or CV changes?
  7. <tuffty/>
    20,900
    3,708
    For clutch on quattro (not FWD), not for CV changes...
  8. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    No it doesn't. You can drain it, but you don't NEED to. If you pull the drive shaft out, it will loose oil but there is no need to drain it all out, just put something under the side that you're pulling the shaft out of to catch any oil that is lost. Just don't forget to top it up again with fresh oil. (75W90 Semi or Fully Synthetic) The same goes when changing the clutch. No need to drain the oil, but you'll loose some when you pull the shafts out.
    Ben
  9. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Not on the 6 speed boxes it won't... the shaft doesn't come out of the gearbox at all...
  10. <tuffty/>
    20,900
    3,708
    If you remove the bevel box to remove the gearbox then you will need to drain the oil...
    You could leave the bevel box on to take the box off but its an cock! to change the clutch on a quattro A3/S3 drain gearbox oil, remove bevel box, remove gear box....
    FWD gearboxes do not need to be drained....
  11. Benjiman46
    551
    24
    Ahhh I do apologise! I didn't know that! I've never done a quattro box so wouldn't know... On 95% of all other front wheel drive boxes in the world then ;)
  12. aragorn
    18,024
    718
    Dont the inner CV's just unbolt? Leaving a stub flange in the gearbox?
  13. <tuffty/>
    20,900
    3,708
    Yep :)
  14. aragorn
    18,024
    718
    Yeh, a lot of FWD cars have the whole thing pull out of the gearbox, but most recent vags seem to bolt on.
  15. bazil
    bazil BOOM BOOM
    135
    So finally got up the shed today, I had removed the shaft earlier in the week, I managed to remove and seperate the inner CV and was glad to see no scoring or heavy grooves etc, but I'm kinda stumped how to remove the outer CV,
    Is it the same as the inner one where I have to remove the cap and release the bearings in order to remove from the shaft, I had a search but no results on outer cv removal ( searching on the iPhone FTL )
    Here is a few pics of how I got on
    Is this part avalible by itself? Anyone per chance know the part number?
    And the outer CV, I'm wanting to take this apart for inspection due to the marking near the bearings, looks like its had a bit of heat on it :(
    Any ideas how to free the cv from the shaft?
  16. murran
    murran Well-Known Member
    1,545
    39
    theres a compression clip on the inside. basically get the shaft in a vice and hold the joint in your hand a give it one decent hit with the hammer. should come straight off. if it doesnt rotate it in the vice and hit it again.
  17. bazil
    bazil BOOM BOOM
    135
    Thanks, just a bit like pulling shafts from a normal FWD box :)
    I didn't want to try that earlier just incase I got it wrong, or it was not the correct approach
