Front drivers tyre looks flatter than the rest but all pressures the same?
Mikey3000 Jul 23, 2013
  1. Mikey3000
    Mikey3000 New Member
    20
    Hi guys,
    I have noticed that my front drivers tyre appears slighty flatter than the rest.
    Now, I run standard 16" alloys with radial tyres so I know it is normal for them to look as if they are flat but should there be a difference in appearance between the o/s front and n/s front tyre. I have triple checked each tyre pressure and they are both running 35psi.
    Is this difference in appearance normal or indicative of a problem?
    I have noticed that the engine is mounted more too the off side of the vehicle. Could it simply be a question of weight distribution or is that just wishful thinking?
    Any help/advice/ideas would be very much appreciated :)
    Cheers,
    Mike
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Are all the sizes/profiles the same?
  3. Mikey3000
    20
    Yep, tyres are all the same size, same make, same model and same tread.
  4. JoeD
    JoeD Member
    537
    10
    Are you sure its not a winter tyre?
  5. Mikey3000
    20
    Even if they were winter tyres, it still wouldn't be normal for the osf to look lower than the nsf
  6. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
    the cars heavier at the front
  7. JudderMan
    JudderMan Well-Known Member
    1,010
    168
    Weak damper/spring. Or you're parked on a slope :)
  8. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    Lay off the acid
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Hole in the ground where the wheel is..?
