Front Discs and Pads
bigyin May 9, 2013
  1. bigyin
    bigyin Active Member
    132
    43
    Hey guys
    Car just returned to me from audi, they tell me that the front discs are close to the end of their life and that I should look to change them sometime soon. I did a quick search but cant find any reccomendations for where to buy the front brakes, can anyone advise.
    I'm running stage 1, but find that the oem set up is fine for the type of driving that I do. I found some EBC High Carbon discs for £160 which i thought was pretty good, has anyone run with these discs. They're the solid variety not grooved or drilled.
    Any info would be appreciated.
  2. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Gold Supporter Team Silver Audi A3 TDi
    484
    164
    43
    I've just ordered some of these discs but I've gone for the high carbon disc's with the v shape grooves.Had the ulitmax discs on for the past 2 years with the green stuff pads no problem with this set up at all.
  3. Lewis583
    956
    91
    Save your money and just get some standard discs from eurocarparts or GSF. Go for a decent brand like pagid/brembo. Same for the pads.
    If you are just using the car for normal use and aren't particularly heavy on the brakes then there is no need for high carbon/grooved/drilled etc.
  4. s3reptdi
    s3reptdi Member
    179
    Arent Pagid just a cheap make they use, Ive had to change many brand new pads in the past becasue the cheap ones just dont work.
  5. Ads
    Ads License to drive
    8,230
    607
    ECP with PARTS20 discount code FTW.
  6. APAutomotive
    APAutomotive Shark Performance Shropshire
    82
    Pagid are used in Many high performance applications as standard eg Porsche Mercedes AMG models
  7. MBK
    MBK Well-Known Member
    1,161
    1,111
    bigyin, it all depends on how you intend to use the car, you say you are happy with the OEM discs/pads so the EBC stuff should be fine for the road. As others have said no real need for the grooved discs unless you are heading on track - the grooves are more about cooling and stopping pad glazing at high temperature.
    PAGIDs pads are great, I've used them on all sorts of performance /tuned cars to great effect. I currently have them on my RS3, which sees the occasional track day. Probably overkill if you just want road use.
  8. Lewis583
    956
    91
    As the others have said, Pagid are a good brand of pad and are used in many OE applications. Another brand I have experience of is Ferodo, the Ferodo Premier range are a good OE equivalent pad that won't break the bank.
    I haven't used EBC myself, though I have read/heard quite a few bad reviews on some of their products and hence have stayed away. They could have got their sh!t together recently though, so who knows.
  9. TDI140
    TDI140 Well-Known Member
    1,623
    174
    Im using standard discs with brembo pads stops well, dont used mintex i used them for a week and my pads crumbled away it was horrible and then grooved the discs which peeeeed me off as i had to replace them
  10. Ads
    8,230
    607
    ATE are OEM too.
  11. bigyin
    132
    43
    I recieved a quote from my local indy for £335 (not including fitting) for EBC discs and Pads or £325 for OEM. The EBC discs are drilled and grooved, but as has been said above I don't need drilled and grooved. ECP are coming in at about £280 for Pagid Discs and Pads, which is very reasonable. Don't get me wrong, I'm not looking for cheap brakes, just don't see any value in buying uprated for an application I'm very unlikely to use given the current OEM set up hasn't let me down so far yet.
  12. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Get a second opinion about the brakes. I've found dealers are happy to say this when the brakes still have up to 40% life in them. Scare tactics....:scared2:
  13. percymon
    percymon Member
    156
    Dealers will advise if they feel they will wear out before the next service is due - if you are on annual service then you probably have 6 months at least in them but start looking at options, or get a free brake check at Kwik-Fit for a second opinion if you don't know one end of a pad from another.
    If you are on long life servicing then forget about it altogether for at least 6 months !
  14. cmgreen
    cmgreen Member
    64
    Go to TPS, get some genuine parts, they last longer and perform better!
  15. ChrisT
    ChrisT Member
    57
    10
    Are you aware any stealer will do the front discs and pads for £270 fitted under the Audi fixed price servicing scheme? That's for any car up to 2.0 engine size including the S3.
    I was going to go down the Pagid route for my S3 but as the OEM kit has done well enough for my needs it seemed the easier option.
