front camber adjustment
Sham101 Aug 1, 2013
  1. Sham101
    Sham101 Member
    286
    20
    just had two front wishbones fitted today with powerflex bushes and the camber has been thrown well out how do you adjust the camber car is an audi s3 1999 apy thanks
  2. Sham101
    Sham101 Member
    286
    20
    forgot to mention the reason i had my wishbones replaced was that one had a big bush on the front and the other had a small bush on the front so they different
  3. <tuffty/>
    20,847
    3,687
    the three ball joint holes are slotted... you need to get it front wheel aligned as it will throw the toe out and you will scrub tyres...
  4. Sham101
    Sham101 Member
    286
    20
    just had it aligned not long ago all was well
  5. <tuffty/>
    20,847
    3,687
    Did you undo the ball joint using the 3 nuts attaching to the arm or the single nut attaching the ball joint to the hub carrier?
  6. Sham101
    Sham101 Member
    286
    20
    the three nuts attaching the arm
  7. <tuffty/>
    20,847
    3,687
    Then I would advise getting the alignment checked... this is where the camber adjustment is made... if you haven't put these back exactly the same the tracking and camber will be out.. S3/TT/LCR arms have slots to allow for camber adjustment...
    One thing of note though with having different sized bushes... the larger ones are voided so will move more under braking... seeing as you have one solid bush on the other side this will potentially give the effect of having a worn bush on the one side and could affect handling or feel under braking and cornering... VAG changed the design as part of an effort to loosen the handling a bit (early TT's were finding their way into ditches backwards) tbh you should have matched arms or at the very least try and poly bush the fronts so they become a little more predictable...
  8. Sham101
    Sham101 Member
    286
    20
    omg just got camber done and the car flys around bends thank you powerflex and tuffty for the advice
  9. ChrisH370
    ChrisH370 Member
    150
    Following the three nuts being disturbed asked tyre shop to adjust the camber but didn't matter what they did with these trying to move the wheel the figure went back to the original value once wheel was grounded. All they were able to adjust was the toe that was out. Tyres no longer seem to squeal but unhappy that camber is not within tolerance. Is there nothing can be done?
  10. ChrisH370
    ChrisH370 Member
    150
    I'm being told camber and castor can be adjusted on S3 8L so would I be wasting my money going to Project Nine?
  11. ChrisH370
    ChrisH370 Member
    150
    Can't be - I meant to write
  12. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Castor can't be adjusted but the camber can be if it's on the cast arms as it should be.
  13. ChrisH370
    ChrisH370 Member
    150
    If camber can be adjusted how is it done, they tried many times with the three bolts loosened off but as soon as weight was back on wheels it went back to original setting which is out of tolerance. I spoke to centre of gravity about it today and they said it can only be done by moving the subframe. Likewise castor.
  14. <tuffty/>
    20,847
    3,687
    camber can be adjusted by sliding the ball joints out... there is not a lot of actual adjustment there and getting it equal requires careful positioning of the subframe to centre it up... there is also very little adjustment in the subframe so not much gains to be had caster and camber wise...
    This thread is a good read
    http://www.audi-sport.net/xf/threads/s3-suspension-and-set-up-guide.56875/
  15. jojo
    28,831
    3,485
    You got to give to some of these guys running these 4WA places, the guy insisted the camber could not be adjusted on my S3 whilst standing underneath my car.(that's what the computer told him). I pointed to my shiney stainless steel camber bars, and told him, are you sure?
