Front caliper identification??
JimmyH
Marham
hello guys,
i need some one to confirm what calipers these are off (A4 TFSI, A4 3.0tdi...)
and what disc size they take 312mm or 320mm?
thank you in advance
To my knowledge id say they off a a4 2.0 tfsi dont quote me thou, but I know for definite the 973 on the rear of the caliper means its left side if it were 974 it would be right side.
If it is for a 2.0tfsi then it would be a 320mm disc needed.
The other way to tell is to look for a code like 11.8012-
something on those lines. Might be able to assist further.
Cheers dude, just done some more research and found them to be 320mm discs and calipers found on 2.0tfsi and 3.0tdi models.
The same caliper is used on the S4 with the 345mm discs although the carrier is different (due to the larger disc diameter).
Yeah, cheers mate, was contemplating S4 345mm discs but due to the price of the carriers 320mm set up will have to do.
