Front Bushes
vanbasten Jul 14, 2007
  1. vanbasten
    vanbasten Member
    Just wondering if anyone has changed the front bushes on their car to the powerflex ones??
    I'm gettign a strange knocking noise from the front drivers side everytime i go over the slightest bump - have been told that its the bushes, but how do you identify which one is causing it and how easy are they to change??
  2. Neil_S
    Neil_S Member
    248
    Thinking/probably am going to upgrade mine in a few weeks, along with KW V2 coilovers.
    Any tips from anyone on changing bushes would be well received here!
  3. terrysingh
    terrysingh Member
    184
    the only bushes avalible from power flex are the lower rear arm, and the upper inner bushes, both sets fit with a little modifiying, i only fitted the lower rear arm ones as the ride got really harsh with the top one fitted.
  4. Neil_S
    Neil_S Member
    248
    I've got a set of Powerflex bushes on order now so I shall have to post up when I have gotten round to fitting them.
  5. terrysingh
    terrysingh Member
    184
    which ones did you order?
  6. Neil_S
    Neil_S Member
    248
    I went for the upper control arm bushes and the lower shock mount bush, I thought I'd install them along with the KW V2 coilovers.
  7. terrysingh
    terrysingh Member
    184
    makesure you grind the outer corner of the bushes round before fitting them, the fit is really tight and they end up spliting if you dont.
