front brake pad problems, advice needed please
Diesel_Seb Jun 27, 2009
  1. Diesel_Seb
    Diesel_Seb Im a Pro Elephant Keeper
    54
    hi guys, im changing my A3 front brake pads on my car and im having a few problems, first question... im looking at them but how do i loosen them to get them out??
    do i need a special tool? :shrug:
  2. S3Steve
    S3Steve Active Member VCDS Map User
    1,608
    17
    Just undo the spring clip, then you need a 7mm allen key to undo the caliper from the carrier, lift the caliper and pads should just pop out mate.
  3. fingermouse
    fingermouse thats me
    3,969
    105
    you may have more problems getting the spring back on they can be tricky ish. Make sure you have taken the cap off the brake fluid reservoir and pushed the cylinder back in a little with a screw driver before you undo the 7mm allen key head bolts then keep a eye on the fluid in the res as you push them back in. Make sure to clean up the contact faces and use copper slip on the area when the pad slides. New pads will probally have a sticker on the rear,
  4. rolo tomassi
    rolo tomassi New Member
    17
    http://www.audidiy.com/
    Theres a few good links here on how to do your pads. I just done mine on Friday. Its handy enough if you have the proper tools.
