FRONT AXLE WEIGHT?
vw754 Dec 8, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,324
    58
    Anyone any idea's on front axle weight? ive got get the lowering springs for my car and i need to know if front axle weight is over 1050kg?
    A4 1.9 TDI (B6) 130BHP SALOON
  2. enda1
    enda1 Member
    436
    According to parkers the weight of your car is 1395kg. If a car has 50:50 weight distribution over the axles then that would be 698Kg per axle. Now being front engined and front wheel drive the car probably isn't 50:50 but it would need to be 75:25 front to rear to have 1050kg over the front axle and the audi's not that bad so i think your safe to proceed
  3. vw754
    2,324
    58
    so if im getting koni spring,with axle weight over 1050 is that ok or should i get a spring which is for car under 1050 ?
  4. enda1
    enda1 Member
    436
    I'd assume you get the spring rated closest to your axle weight. A higher rated spring will be stiffer so as to not compress under the extra weight of the car, and a stiffer spring will give a harder ride.
    I'd have thought koni would have the springs specified by car type.
