Front ashtray trim removal
RC Apr 3, 2008
  1. RC
    RC New Member
    23
    Might sound a little stupid, but can anyone advise on how to remove the front ashtray trim?
    Changing that piano black to the brushed aluminium!!
    Cheers,
    R
  2. PNH80
    PNH80 Low life livin' the high life.
    1,633
    Finally went for the brushed aluminium then did you! How much did the kit cost? 300 big ones?
    I've decided to keep piano black in the middle but i'm looking for ali door trim to mix it up a bit!
    As far as removal goes.... Don't be shy and simply pull it. I've just removed the gearstick surround to fit a new gearknob and i was a bit worried about breaking clips. They're not flimsy things and they snap solidly in and out. I didn't remove the ashtray but if you look at my thread further down titled 'New gearknob and gator'....someone in there has posted how to do it.
    Paul.
  3. Boydie
    Boydie Guest
    The ash tray trim is difficult and i did end up scratching it in two places but lucky its at the back and is not visible!
    Basically, you need two thin flat head screw drivers and you have to pry the trim off as it is clipped in tight
    When you get it off, make sure you make note on how it is positioned because when i went to put the new trim on, the edges didnt meet up properly and I still clicked in place which meant i had to take it apart again and thats where i scratched it :(
  4. RC
    RC New Member
    23
    Thanks guys!
    The ali trim was £312 delivered!!
    Looks good though!!
    R
  5. Boydie
    Boydie Guest
    holy foooooooook!
    I paid £100 on ebay for mine
  6. Kontraband
    Kontraband Active Member
    2,000
    ahahaha rub it in Boydie!:haha:
  7. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    I paid £280 delivered from vagparts, remember to mention your an audi sport member
