Front Arm rest
sprout99
North East - Dodge city
Looks like my arm rest has packed in.
Release mechanism is not working properly.
Any suggestions on fixing it?
How much is a new one? :banghead:
or should i go and sit down first?
Definately try to fix it...
I've seen a few posts in this forum about repairing/upgrading the various pitiful mechanisms in the armrest; a quick search will probably yield plenty of useful info... I'm sure there was a thread in the last month or two about such a task?
Also, Definetely sit down for the replacement price... A dealer will charge the earth, www.vagparts.com are a bit cheaper - usually between £170 and £200 for the whole shooting-match depending on the upholstery - but of course you probably don't need the whole lot...
Regards,
Rob.
4 flocked screws were hidden!!!
All done now. i used a 95mm long 4mm diameter steel rod
Drilled right through button and a dot of super glue for good measure on inside.
Just need to tighten nut under handbrake that is loose and causes rattle.
(was being a bit rough last night)
I'm a happy bunny now. Job took 30 mins to do using metal bar route.
one of the advantages of being in an engineering environment.
Thanks again to NeilS3.
:beerchug:
613
705
851
863
894
HTC
