Front ARB bushes need changing
doublem_1 Oct 13, 2011
  1. doublem_1
    doublem_1 Member
    500
    I have a 52 reg A3 TDI Quattro. The front ARB bushes need replacing. I have seen different sizes (18mm,19mm,21mm) mentioned. Can anyone confirm which size I need?
  2. SiGainey
    SiGainey Member
    506
    10
    Best just to go to Audi m8. Assuming you have a standard ARB, they will be able to do a lookup on your VIN and tell you which is the right part :)
  3. doublem_1
    doublem_1 Member
    500
    Cool, so do they supply the new bolts and brackets too?
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    It's normally easier just to get a full new ARB for around £70 as the collars tend to break.
  5. Jason.s
    Jason.s Active Member
    2,879
    348
    They can supply bolts and clamps but they wont come with the bushes. All seperate. VIN supplied will tell you what sizes are needed
  6. a3tdi2001
    a3tdi2001 Member
    437
    Pretty sure they made an updated bush with a smaller hole to replace the plastic collar which can then be removed and put in the bin where it belongs. Any chance you could post the prices and part numbers if you phone the dealers as I'm after a set myself? Cheers.
  7. doublem_1
    doublem_1 Member
    500
    Thanks for the help people. I shall phone them up soon and report back.
  8. rich4130
    rich4130 Member
    41
    Just measure the ARB with some vernier calilipers, don't even need the wheels off.
    Get some longer bolts, (the balljoint to wishbone ones do well) Makes it much easier
  9. doublem_1
    doublem_1 Member
    500
    OMG didn't think of that! Thanks :)
