Front anti-roll bar & lower suspension arm bushes..
shah23 Dec 16, 2008
  1. shah23
    shah23 New Member
    17
    Hi guys,
    Wondering if anyone can help here. My car was recently mot'd, everything was fine and the passed its mot.
    However the report did suggest that i have my front anti-roll bar synthetic bushes and lower suspension arm rubber bushes replaced in the coming months.
    I was just wanting to know if its going to be an expensive job to have done. I wont be taking it to the dealers, because i know they will be expensive.
    Any suggestions?
  2. spiker
    spiker usually growling at something
    200
    hi shah
    nothing too serious here my friend - perhaps £200-£300 worth of work
    You might consider poly bushes depending on your preference for a little bit extra
    How many miles have you done ?
  3. Swifty_Boy
    Swifty_Boy New Member
    22
    I am having the wishbone bushes and the front ARB replaced on Monday at APS at a cost of £350 all in, which I think is OK .
    Car has done 100k and as far as I know these are the first replacements it has had. Seems to all be motorway miles though.
  4. fingermouse
    fingermouse thats me
    4,027
    120
    Just remember the front sleeves on the S3 arb can split under the bushes then it new arb time
  5. leecs3
    leecs3 thinking about stuff
    604
    ask santa for a set of H&R ARB's. They transform an S3's handling and steering feel.
  6. spiker
    200
    I have upgraded the front and rear arbs to neuspeed 15/19 Front rear - added 2 adjustable tie bars at the back - neuspeed and forge and had the rear trailing arm bushes replaced
    the shocks and springs were also replaced
    the ride has been transformed - it handles much much better
    £350 sounds about right for the work - I am sure you would have needed them at 100k
  7. domburg
    domburg Member
    89
    spiker - did you replace the shocks and springs with OEM items or did you get aftermarket ones?
    dom
  8. DPM
    DPM Site Sponsor Site Sponsor
    5,083
    227
    Agree with Lee, great choice the H&R ARBs.
    Damian @ DPM
  9. spiker
    200
    Domburg - Hi
    Koni FSD's and eibach pro kit springs - but in heinsight should have gone Bilstein
  10. domburg
    domburg Member
    89
    hi spiker, cheers fo that, im planning to replace/improve the suspension and components on mine in the new year, justy out of interest howcome u say u'd prefer the bilsteins to the koni's
    dom
  11. spiker
    200
    well the konis raised the ride height about 10mm upon fitting ( despite everyone saying it wouldnt - awesome / forums / koni ) - its settled down since but its still about 7-8 mm higher than standard
    On the motorway the ride was very bouncy - this was solved when i upgraded the front and rear arbs . Now all is well and the konis do a good enough job
    I think if everything is set well with the supsension then they are probably perfectly ok - its personal choice i suppose other people may prefer the bouncy feel as its less harsh.
  12. shah23
    shah23 New Member
    17
    hi thanks for getting back to me. the car has just done 50k, and is backed by full audi history. the rear bushes were replaced at dealers before i bought the car.
    Im still kinda confused as to which bushes i should go for.. and where is the best place to get them from? are dealer parts any good?
  13. shah23
    shah23 New Member
    17
    also, it only says to replace the bushes.. so im guessing this does not include both ARB's and just the bushes??
  14. spiker
    200
    Shah - you have some options here
    You need lower suspension arm ( i presume this is at the front) and front arb bush replacements
    If you plan to keep the car for a while it may be cheaper in the long run to
    replace front and rear arbs ( they come with their own bushes) i run 22mm front 19mm rear which works well for me
    replace both sets of front wishbone bushes with polybushes
    optionally consider replacing the rear trailing arm bushes too with polybushes
    That lot will set you back well over a £1000 possibly closer to £1500 with labour but this will transform the handling and keep the car nice and tight for the next few years
    OR
    on the cheap - just replace the arb bushes and lower bushes with the standard rubber ones as required at about £300+
    Having done option 1 i would highly recommend it but its down to cash at the end of the day - the S3 is not great when comparing its handling to similar class cars and if you really want to drive it and enjoy it then it will cost - but be well worth the investment if you intend to keep the car a few years
    your call
  15. mat20vt
    mat20vt Member
    450
    i went bilsteins on my a3. koni fsd's on my golf did not lower the car.
    bilsteins on now, with 30mm lower springs, and h&r cup kit. supplied by DPM and Badger5. handles great. i'd recomend that setup
  16. Dennis Moeller
    Dennis Moeller Member
    444
    Real nice setup that I will look into. Do you have links to where you bought it? Much appreciated :yes:
