- Joined
- Nov 24, 2010
- Messages
- 15,084
- Reaction score
- 1,131
- Points
- 113
- Location
- Plymouth
- Website
- wheelsnwires.blogspot.com
I went to get my tracking sorted out and the garage said my track rod ends need replacing.
Off I went to get the parts and replaced them my self.
All done and I'm back at the garage getting the alignment done.
On the way home I noticed that the car would go to the right with the wheel straight but it appeared to track ok.
I went back to the garage and had a chat to the alignment guy who came out and met me in the car park.
I mentioned that the car steers to the right if the wheel is straight.
He explained that the front wheels are tracking fine and the issue is with the rear wheels/axle.
He went on to say its possible that the rear axle at fault cause its a solid axle and there is nothing that can be done about it.
Fair enough, I asked him if its possibly a bush at fault, he said it could be but due to the age of the car (1998) and miles (120k) its not really worth spending the money on getting it correct and its common fault on most solid rear axle cars.
Is he right in what he was saying?
Is there a way to fix it?
This is the information on the print out he handed me.
Front Toe
Initial Specification Final
Left 1.4mm 0.5mm 1.6mm 1.0mm
Right -3.0mm 0.5mm 1.6mm 1.2mm
Front Camber
Initial Specifications Final
Left -1.04 -1.00 -0.17 -1.16
Right -0.56 -1.00 -0.17 -0.54
Front Toe
Rear Camber
Left -1.94 -1.83 -1.17 -2.02
Right -1.20 -1.83 -1.17 -1.15
Rear Toe
Left 3.2mm 0.5mm 1.8mm 3.4mm
Right -0.2mm 0.5mm 1.8mm -0.5mm
Rear Thrust Angle
Initial Final
-0.27 -0.31
Total 3.0mm 1.1mm 3.6mm 2.9mm
Rear Thrust Angle
Initial Final
-0.27 -0.31
