Front and rear washer not working, but headlight washers are fine!
guinness May 18, 2010
  1. guinness
    guinness New Member
    My S3's front and rear washers ain't working. Headlight washers work fine though!
    Checked that the fuses are fine, and couldn't hear the pump running. Put a voltmeter to the terminals going into the pump, got someone to activate the wiper/washer but didn't get a reading. Where should I look next? Any pointers appreciated!
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    If the electrics are fine, I would check the pipes for blockages or for connection to the bottle/pump.
  3. guinness
    guinness New Member
    well, the thing is the electrics don't seem to be fine for the front and rear washer pump as i don't get a voltage reading even when the wash/wiper stalk is activated. but the fuses are fine.
    am i right to assume the other pump is for the headlight washer pump?
  4. guinness
    guinness New Member
    hi, this is still stumping me. any suggestions guys? tks.
  5. rossbrownlee
    rossbrownlee Ross_S4
    719
    headlight washer pump is on the front of the reservoir next to the headlight rear cover if that is any help.
    maybe your stalk switch is knackered?
