front and rear lights
kirsty76 Sep 25, 2010
  1. kirsty76
    kirsty76 Member
    255
    hi does any one know if i can fit these as a direct replacment for the original ones, not having to mess with wires or anything.
    eBay - The UK's Online Marketplace
    also the facelift 2009 rear lights are these easy to fit or does it require changing lots of things? i have tried to find a guide to fitting them.
  2. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Those front lights are standard A3 HALOGENS. . There is no differance afaik between s line and se sport etc.
    The rear lights are very very easy on the 3 door. You change them the same way you would change a bulb in the cluster. Look in your hand book and it will be clear
    HTH
  3. kirsty76
    kirsty76 Member
    255
    so all i would need to do for the rear lights is remove the actual light and replace it with the new 1?
    so the front is jus unscrew original and put the new 1 in its place and it will fit perfectly?
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    yes and yes! 5 mins a side maximum! Lots of people have upgraded the rears to 09 and now 11 spec.
    As for the fronts in your link, they are the same as the ones you have so dont buy them!
  5. mike foster
    3,967
    Your mods so far say you have xenons. Why would you want to change back to halogens ?
  6. kirsty76
    kirsty76 Member
    255
    no i dont have an s line they hav black insides mine are grey and i think they may have a hole.
  7. scottie123
    1,972
    you can get them cheaper than that on ebay. If they are black, I would imagine someone has sprayed them that colour!!
  8. kirsty76
    kirsty76 Member
    255
    does the s line not come with black insides of the headlights then?
  9. heeman10
    heeman10 Audi driver since Dec 08
    375
    If you want to downgrade to halogen lights I'll gladly swap for your xenons!
  10. Lee_R
    Lee_R Active Member
    2,499
    12
    No they are identical on all models! The seller is after makin a quick buck
