From 3000rpm to 4000rpm almost missing sound
Ben2487 Feb 12, 2013
  1. Ben2487
    Ben2487 Active Member
    249
    111
    43
    Bare with me on this but difficult to explain over text!
    Say I'm in third and put my foot down from 3000rpm to 4000rpm it almost like a pulsing sound from the air being sucked in but after 4000rpm it seems like the engine is using all the air being rammed in and is fine,
    And seems worst when I start to put my foot down at 3000rpm, if I boot it from low down seems to be less noticeable?
    I recently fitted a Bluefin so maybe the ecu is still learning and try to cope with the extra air from the revo induction kit, don't think its effecting power but just doesn't sound good,
    Filmed a video putting it on youtube now once I trimed it,
    Any ideas do you think it will clear itself?
    12022013022 - YouTube
  2. mjr901
    mjr901 Guest
    Normal flutter as far as I can tell.
  3. Ben2487
    249
    111
    43
    And what is flutter?
    Is it just the turbo spooling up??
  4. mjr901
    mjr901 Guest
    34 seconds on the this video
    is this the noise your on about? :)
    Different car, same engine..
  5. Ben2487
    249
    111
    43
    Yea sounds exactly the same about the same revs too!
  6. mjr901
    mjr901 Guest
    Eitherway, sounds 100% normal. Its the DV. Its what they do.
    What year is your car?
    If your still worried, Check the DV to make sure its Revision D (or G i think aswell now) and not C for example as the earlier ones had diaphragms that split, until they were changed for a different piston operated design.
    Judging by your white DIS needles etc, yours is a later model, but it doesnt hurt to look.
    Here a picture of the 3 torx screws you need to undo to check :
    make sure you keep a firm grip on these and dont drop them down into the engine bay, I've had fun finding one of these *******s!!
    The metal housing you see here, stays on the car normally. so your only looking to take of the black plastic part.
    Check part number on the side, and boom, your wiser.
  7. Ben2487
    249
    111
    43
    Its 2010 59 plate,
    glad it sounds normal I forgot to mention I haven't long fitted a forge dv,
    need to make a signature,
    thanks for the advice mate.
  8. mjr901
    mjr901 Guest
    No worries :)
