From 2004 Xenon to 2006+ Bi-Xenon, Can it be done?
Joe90k Feb 23, 2010
  1. Joe90k
    Joe90k Speed doesn't Kill!
    227
    As the title says can I swap the headlights I currently have (2004 Xenon headlights fitted OEM) to 2006+ Bi-Xenons? Do I need to change the control module or anything or is it a simple change of coding with VCDS.
    TIA
    Joe
  2. NHN
    29,352
    1,720
    You will need to swap your plugs to 14 pin & rewire also, not a simple coding change, I did it properly with the plugs & repair wires as fedup with **** adapters & adds more clutter to your car.
  3. L80EWY
    L80EWY Member
    326
    12
    Ive got a 2004 Sport with standard lights, will 2007 Oem Xenons plug straight in if anyone knows?
  4. NHN
    29,352
    1,720
    No.
  5. Joe90k
    227
    What's the rough price of the wires and plugs? So it's just a re-wire and thats it?
    Cheers,
    Joe
  6. Joe90k
    227
    I guess you have to add the extra wires to the car, where do they go?
  7. NHN
    29,352
    1,720
    One word mate, Elsawin.
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    for the adapting looms check out kufatec, i dont have pinouts here to give you more info about the wires though i can tell you nhn is your man when it comes to this
  9. L80EWY
    L80EWY Member
    326
    12
    Was that to my question? i thought they were a straight swap s3 headlights to a sport :(
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    no module looms and levilling sensors all need added or changed
  11. NHN
    29,352
    1,720
    You said is it a straight swap, I said no mate, different plugs exactly as per my reply to Joe originally, however I do know all about the mod.
  12. rickyquicky
    rickyquicky Member
    342
    Whats the difference between xenons and bi-xenons?
  13. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i belive tthe bi xenons turn to bend round corners as you drive round em
  14. Joe90k
    227
    No Bi-Xenons have high and low beam Xenon where as Xenon is low beam xenon only with high beam halogen.
    Joe
  15. Joe90k
    227
    Annoying, I have it but it's not working the person I bought it from on eBay isnt that helpful either, it has no option in the language box just some squares instead of letters.
    Need to get it sorted. Apart from the wiring loom change is there any module or sensor change?
    Joe
