Found coolant leak - what is this part?
Squirrelofdoom Jun 25, 2013
  1. Squirrelofdoom
    Squirrelofdoom Member
    671
    23
    Hi guys,
    So I've been losing coolant recently, was worried it was off the recent turbo work I've done, but no worries, that's fine. I found the leak on the right hand side of the head, underneath a 4-way coolant junction that bolts to the head via 2 allen key bolts (where the temp sensor plugs into). I've attached a picture of what I can see.
    I think it is this 4 way junction that is leaking given where you can see the pink coolant on the gearbox below it. However, there is also something I've circled in red which also appear to be wet - but I don't know what it is or if I should be investigating that too.
    So, could someone help out with:
    1) What is the 4 way junction thing that bolts to the head? Does anyone have a part number for this? Do they usually leak when they get a bit old?
    2) What is the other part that appears to be wet? Should I be worried about that?
    Thanks guys!
    Aran
  2. superkarl
    superkarl MAN OF STEEL
    9,421
    2,381
    part number: 06A 121 132 AP - i paid £11.28 with 8% discount from TPS.
  3. Squirrelofdoom
    671
    23
    Thanks Karl, guess you've had the same problem as me before then :)
  4. superkarl
    9,421
    2,381
    yeh its common for the housings to crack. i couldnt even see my crack till i got it off but knew it had to be that.
  5. Squirrelofdoom
    671
    23
    Cool, I'll order one today. Thanks mate. Any clue on the other boss off the head which seems like it's weeping?
  6. superkarl
    9,421
    2,381
    looks oily to me?? in which case would be the rocker cover/half moon seal imo
  7. Squirrelofdoom
    671
    23
    yeah, probably is. Also, just noticed your sig - hilarious :)
  8. Squirrelofdoom
    671
    23
    cool, went to TPS and got one! Thanks mate
    superkarl likes this.
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    They usually crack on the molding seam, so seem normal once off....
