forte engine flush
Bellic May 22, 2007
  1. Bellic
    Bellic Member
    265
    is it ok to put the forte engine oil flush in the 1.8t engines? as i had seen somewhere audi say not to use engine additives?
  2. tonyt102
    tonyt102 Member
    95
    I think they mean products such as Slick 50 etc. Engine flush, if not used on a regular basis can loosen bonded deposits on higher milage cars. Just what I learned back at car college anyway. I've just had a major service including engine flush.
  3. Bellic
    Bellic Member
    265
    i think vag do sell the forte engine flushes?
  4. HTC
    HTC Active Member
    3,428
    9
    why do you think you need to use flush?
  5. Bellic
    Bellic Member
    265
    just a thought it might do good but i will leave it now as seen some bad done by flushing
  6. emzino
    emzino Active Member
    1,231
    Is engine flushing when you use Redex?
  7. nickelvery
    nickelvery RS4 B5 380bhp
    545
    Redex is used for cleaning the injectors or carbs.
    Engine flush goes in the oil and there are many brands. One person I know uses some desiel.
    Hope this helps.
  8. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    flushing is unlikely to be necessary in a modern engine as most modern oils have detergents anyway.
