According to the Forge Motorsport website, there are many different versions of the Twintake, each specific to a particular model of car, so it doesn't look like you can mix and match them, unfortunately
xx
This is copied from their site -
However, every version of our Twintake kits are different in some way and are specific to one vehicle model. The kits are not interchangeable and we do not sell the components separately. If you are in doubt as to which kit is required please follow this guide.
1.Determine manufacturer â Audi, SEAT or VW
2. Determine model - so for a VW Golf this could be Golf MK5 or Golf MK6
3. Determine Engine â All our Twintakes are for the 2 litre VAG group petrol engines only. The earlier engine was found in the MK5 Golf, badged as the FSi in the UK market, and easily distinguished as it incorporated the air filter in the engine cover. The later engine, badged in the UK as TSi, is found in some MK5 Golfs, all MK6 Golfs and is easily distinguished as the OEM air filter box is separate from the engine cover.
4. Double check your MAF sensor part number. Since 2009 the VW/Audi gorup have been changing the MAF sensors on their cars to a 'more advanced' sensor which resists tuning and has the mounting plate mounted 180 degrees rotated from the original. However, many cars produced since 2009 still have the old sensor. Please check the picture below to make sure you have the correct MAF sensor - the part number is printed in white on the top. We currently have no solution for the new MAF sensor on any car.
Vehicles / Twintake part numbers
Audi S3 with OEM air filter built into engine cover â Pt No.FMIND12E
Audi A3 with OEM air filter built into engine cover â Pt No.FMIND12G (coming soon)
Audi A3 with OEM air filter separate from engine cover â Pt No.FMIND12H (coming soon)
SEAT Leon Cupra with OEM air filter built into engine cover â Pt No.FMIND12D
SEAT Leon (not Cupra) with OEM air filter incorporated into engine cover â Pt No.FMIND12F
VW MK5 Golf with OEM air filter built into engine cover ie BPY engines (2005-8 in USA or 2005-9 in UK) â Pt No.FMIND12
VW MK5 Golf ED30 with OEM air filter built into engine cover â Pt No.FMIND12B
VW MK5 Golf with OEM air filter separate from engine cover (CCTA 2008 on in USA ) â Pt No.FMIND12A
VW MK5 Golf with OEM air filter separate from engine cover (CBFA) Pt No. FMIND12A and FMFIL28**
VW MK6 Golf (USA only *) with OEM air filter separate from engine cover â Pt No.FMIND12J
VW Scirocco R with OEM air filter incorporated into engine cover â Pt No.FMIND12K
