FORGE POLISHED NON-RES HARD BOOST PIPE
shanejess May 5, 2011
  1. shanejess
    shanejess Guest
    carnt wait to get this mod which replaces the grey hard boost pipe, a high quality polished non resenated pipe from forge, apparently sounds awesome and looks brilliant polished without the infamous dent. ive hand polished inlet manifold so polished pipe will look good, redlines TT has the mod and they say it makes the car sound fantastic. forge had teething problems to start bur has now been sorted and will be available very soon, AWESOME in manchester have ordered them for stock at 71 pounds plus vat which is a very good price and a lot of mod for the buck, they will be available from awesome from the end of next week. im a thicko so if anyone could post pic off forge site of the pipe would be appreciated cheers. code is fm225bhp, under audi S3.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    £85 for a bent alloy pipe.....mmmm each to their own
  3. tom792
    tom792 Boost Addict :)
    94
    There ya go mate
  4. superkarl
    superkarl MAN OF STEEL
    9,555
    2,455
    its just a pipe. waste of money. mine is as polished as that
  5. tom792
    94
    Forge says it "this polished alloy non-resonated boost hard pipe replaces the turbo resonated turbo outlet pipe ( runs from the turbo down the left hand side of the engine) on the 1.8T 225 hp engines as found in the Audi TT S3 225 hp (8N), SEAT Leon Cupra R. (uses original mounting brackets)
    The removal of the noise reasonator allows unobstructed flow on the discharge or boost side of the turbo. We have also modified the “dent” in the underside of the pipe that allows it to clear the cam cover and made it as shallow as possible, to just allow the pipe to fit, but not overdone as to impede airflow. These combined modifications give quicker spool up of the turbo and effectively reduces the load placed upon it."
    So I can see it does have its uses. However i can still see better things to spend 85quid on! But with extensive modifications suppose it may be worth it to quicken turbo spool.
    EDIT: **** SPELLING!
  6. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    sales guff....
  7. Westy
    Westy Well-Known Member
    17,443
    1,105
    I'll stick to my de-baffled matte black charge pipe that hasn't cost me anything ;)
    Seriously though you really wont notice much difference for your £70+
  8. finesse
    finesse Active Member
    2,805
    Lol so what there's a dent on the baffle?
  9. Westy
    17,443
    1,105
    The dent is on the under side of the pipe so that it fits over one of the fixing brackets. Forge are bragging about increased flow as their pipe has had this dent smoothed out.
  10. superkarl
    9,555
    2,455
    the pressure difference and flow over that dent will be so so small it'l be immeasurable, that sales guff above posted by tom is funny
  11. Westy
    17,443
    1,105
    :iagree:
  12. djarchive
    djarchive Member
    287
    Westle: Could you elabourate on how long it took / plenty of messing swearing at it or was it an easy-ish job? Just take a carefull chisel to it + chip away at it once removed?
    Joe
  13. Westy
    17,443
    1,105
    Huge ball ache Joe. I used a dremmel to cut a few slots into the baffles to weaken them then I set about it with pliers, chisel and hammer, and a massive crowbar. Took about 30-40 mins to get it all out. I did before and after VCDS logs and it made no difference to airflow and didn't really sound that much louder!
  14. djarchive
    djarchive Member
    287
    Might just leave it alone then. Hate to punch a whole threw it rendering it completely useless.
    Things like that ALWAYS happen to me lol
    Thanks matey :music:
  15. tom792
    94
    Just to clarify i do realize what forge are saying may be slightly true but will make hardly any difference. Just depends how much money you have to waste i suppose.
  16. shanejess
    shanejess Guest
    i really like this mod and when they are in stock im getting one, my opinion they look great and apparently sound very good, i think their very cheap at 71 plus vat.
  17. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    How would you log the before and after differences?
  18. dancarpy
    dancarpy S3 DCY
    236
    its the world vs shane ! :D haha
  19. Sandip
    2,456
    99
    Did some logs recently so we'd log the same blocks with the Forge pipe and see if there is any difference, once Shane's got the pipe on i'll try an organise another logging session :)
  20. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    I personally think what Forge have said about the part is true and makes sense, however I dont think it will make any noticeable performance increases. May make some increases but probably not enough to notice. Should sound good though.
  21. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    I painted our cam cover today, cost a fiver and easily adds as many bhp as those forge pipes.
  22. MUSH
    713
    12
    Should do the inlet too! Looks good. Dont really believe them forge pipes do anything...
  23. Westy
    17,443
    1,105
    Klappe, I hope you did the gasket too. Oh and do the inlet mani too like mush said ;)
  24. <tuffty/>
    21,586
    4,053
    I concur.... this kind of part fits in with a lot of the other stuff Forge sell and there is no doubt a lot of demand for them... I see quite a few 'blinged' SEAT's and this is the sorta thing that is right up thier street...
    Performance wise there may be little to shout about but then this is the case for a lot of the more 'dress' items available... doesn't stop peeps buying them...
    I still use the original charge pipe on my S3 with no detrimental effect (as does Welly) but if you are 'dressing' your engine bay then its a nice addition (if thats yer bag...)
  25. 16Klappe
    5,795
    1,186
    Of cause, including the center gasket for the lead holes.
    My job for tomorrow is the inlet and to dress the hoses/have a clean up.
    Its Jarrod/Jardo btw, are you called Mark or am I thinking of someone else?
  26. Westy
    17,443
    1,105
    You are thinking of someone else mate. My name's Neil.
    Well jardo, get some more pics up later ;)
  27. finesse
    2,805
    ASN love boat :)
  28. S3KO4
    S3KO4 Member
    850
    I think dave has his one polished who he replaced with someone on here, I took mine off to have it polished but changed my mind as I thought the ciramic coatting does a really good job at limitting heat transfere
  29. 16Klappe
    5,795
    1,186
    No pics for you! Instead of cleaning the car I spent all afternoon trolling the pubs with my girlfriend and her parents, and I am pissed as a fart.
    Maybe tomorrow If yoh are lucky :)
  30. s3dave
    10,110
    736
  31. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    Lmao
