Forge DV - Tips On How To Fit One Please
Iggu Apr 4, 2009
  1. Iggu
    Iggu Active Member
    1,229
    I'm helping my mate fit a Forge DV to his Ed30 tomorrow - so the location is at the front of the engine.
    The instructions which come with it are for the Golf GTi - where the DV is at the back of the engine near the turbo - so I need a few tips. Anything you can suggest will be gratefully received but in particular I have these questions:
    1. What is the best place for the solenoid bracket to be fixed ?
    2. Do we need to grease the DV unit before installing it or just put it on as it comes ?
    3. Does it matter how long the hoses from the DV to the solenoid are ?
    4. Do Forge instructions exist for installing these to Ed30s or are you supposed to just "wing" it ?
    Anything else you can advise would be great. Thank you.
  2. Timbo_S3
    Timbo_S3 Member
    57
    warrencox wrote up an excellent tutorial.
    First thing I would say is why not try the new revision H OEM DV (part # 06H 145 710 D)? It's much simpler and the car stays "stock".
    Secondly, and they don't tell you with the Forge instructions, if the car has been chipped, you need an upgraded (yellow) spring. There's also a service kit you can get from Forge which has an anodised 'plunger'. This apparently works better than the one they send out initially. Both the spring and the plunger are easy to fit afterwards.
    Let us know how you get on
  3. dc240969
    dc240969 Member VCDS Map User
    925
    Thats interesting. how much is an OEM new version DV
  4. Timbo_S3
    Timbo_S3 Member
    57
    It was $AUD106, so I'd reckon less than £50 in UK
  5. mhill
    mhill Member
    323
    Got any more details on this?
  6. Timbo_S3
    Timbo_S3 Member
    57
    What more would you like? The part number is quoted earlier in the thread
  7. Rabbit222
    Rabbit222 Active Member
    708
    123
    43
    Quoted by APR
    we were recently working on a few new vehicles and discovered another rolling change VW/Audi has made. Apparently they have upgraded the Diverter Valve, again, to the new part below. It looks pretty solid from what we can tell and the spring included feels a bit stronger as well. The new part number is 06H 145 710 D. We've seen little to no problems with the OEM G valve, however we'll be testing this new OEM part with all our setups.
    From looking at ETKA it appears this new valve will come standard on all 2.0T's from now on so there may be a few people out there with this part already!
    I just want to point out, we are not selling this part or keeping an inventory of them so I'm sorry, I can't sell you any. If anyone wants to pick one up, check with your local VW parts department to see if they have began stocking the part! Looks like this is going to be a cheap solution for everyone running the early 2.0T DV's!
    Here are the photos!
  8. mhill
    mhill Member
    323
    Something like what Rabbit222 has posted would more than surfice!
  9. gadgesxi
    gadgesxi Member
    158
    Will this new DV fit the B6 1.8T ?
    Better buying this then a 80 quid forge job i think!
