Forge Dv, Fitting On Facelift S3??
Phil_T Dec 10, 2009
  1. Phil_T
    Phil_T Revo Stage 2+ Audi S3
    240
    I havent got the tools to fit it & take off the old one so went down to Halfolds looking for 5mm allen wrench or allen socket with extension, 3mm allen wrench & 1/8 inch allen wrench as per forge instructions but all I could see where torx or star attachments & none of these were in sizes there where by code like TX20 etc?
    Can anyone tell me what I need as looking under the bonnet then going back in they looked like star keys not torx but like I said there were not in sizes but code & number.
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    The bolts holding the DV in are torx bolts yep and they're coded by a T then a number. I don't know which one you need but it's worth buying a set as most bolts on your car are torx and they'll come in handy in the future.
    EDIT: Apparently they can also be coded with a TS## or TX##. The numbers will be the same sizes though and that's the important bit (bit! Get it?! :happy:).
  3. Phil_T
    240
    Hmm they dont look like torx as they aint as many little points, they look like a star bolt & if I need a 3mm & 5mm TS or TX 5 & 3 is 100% too small
  4. Staz
    6,206
    67
