Forge blow off adapter or kit??
jordcoe Jan 20, 2013
  1. jordcoe
    jordcoe Member
    40
    The blow off adapter:
    Forge Blow Off Adaptor for VAG FSiT TFSi Turbo Engines - A3 (8P) - Audi - Shop By Car
    or
    The blow off valve kit:
    Forge Blow Off Valve kit for 1.4TSI/1.8TSI/2.0TFSI Engines - A3 (8P) - Audi - Shop By Car
    can anyone thats got either of these or just knows about them tell me the difference between the two?
    as far as I know they both provide the dump valve 'psssshh' lol which is all I'm after really, so is there a decent reason why I should fork out the extra and get the valve kit?
    Jord
  2. mjr901
    mjr901 Guest
  3. jordcoe
    jordcoe Member
    40
    well I won't be getting that then haha
    I'll go for the blow off valve kit then and see how that goes!
  4. mjr901
    mjr901 Guest
    + actually the other one produces the same sound, the only difference being, instead of being electronically controlled, its vacuum controlled.
    Best off going to an Intake if you havent already as thats where most of the noise comes from.
  5. jordcoe
    jordcoe Member
    40
    ok, thanks for the help anyway mate!
    bought the car with a K&N induction but to be fair I think its pretty ****... I want the neuspeed p-flo, mainly for its looks though.
    just found this video:
    ECS Tuning: VW/Audi 2.0T Forge Diverter Valve & Blow-off Valve DIY - YouTube
    even though its a mk6 TSI it shows the difference, pretty decent fitting guide as well! sure the TFSI engine isn't much different for fitment
  6. mjr901
    mjr901 Guest
    Fitment is the same, and yes that video is very informative.
    The K&N Typhoon, thats near as damn it the same as the Neuspeed isnt it??
    My P-fo thread below
    http://www.audi-sport.net/vb/a3-s3-...454-p-flo-fitted-some-pics-inside-fitted.html
  7. jordcoe
    jordcoe Member
    40
    yeah I think the Typhoon is pretty much the same, i've just got the ****ty 57i cone filter though.
    cheers for the link mate.
  8. mjr901
    mjr901 Guest
    Ignoring that this engine cover is the golfs version as its actually the same as the S3's just aesthetically different on top , is it like this? ImageShack� - Online Photo and Video Hosting
    Does that mean you have double filteration??! as the filter is built in to the standard air box at the back?
    If its is.... that'd be immensely restrictive!!
  9. jordcoe
    jordcoe Member
    40
    mine looks exactly like that...
    not had it off to look to be honest mate, not really paid much attention to anything under the bonnet yet
  10. mjr901
    mjr901 Guest
    If i was you, id be pulling the engine cover off, pull from opposite corners and give it a hard rock and it'll be off.
    Then have a look for the built in filter in it and see if your doing double filtration, wont take 15 mins, if that.
  11. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,094
    581
    if you get the decent cold air intake, you'll pretty much get the desired noise (someone will back me up shortly).
    i got the similar noise with oem rev d valve and with forge valve.
    the first one (spacer) is usless and i guess you'll even loose some power with it as it dumps air in the atmosphere.
    i wouldn't throw money on that.
    second one is a good piece of kit.
  12. mjr901
    mjr901 Guest
    The second one is essentially the same bit of kit, it simply eliminates the diaphragm which is prone to wear, it still 'blows off'. Yes it uses a spring which will be more hard wearing, but the point is, its vacuum operated, not electrically. However the fault with the original system isnt the electrics, its the rubber diaphragm.
    If you still want the DV to remain active, like the original, you need this kit Forge Motorsport | Alloy Fabrication
    It will use a spring instead of the diaphram, and continue to recirc the air and not blow it off, it'll create a noise to an extent but will not be as loud as the BOV valve mentioned before.
  13. S.
    2,094
    581
    thats why i think it's maybe better to buy a decent intake kit.
  14. mjr901
    mjr901 Guest
    Yup, For the average user, the setup id go for would be : ITG intake or similar, Rev D DV valve.
    If your Rev D valve keeps breaking (unlikely) then buy this Forge Motorsport | Alloy Fabrication
    As this replaces the diaphragm with a spring and continues to recirc the air. :)
  15. Reload
    Reload Bird is the Word!
    367
    50
    Thought the Rev D valve used a spring anyway, the Rev C was the one with the crappy orange rubber diaphragm?
  16. mjr901
    mjr901 Guest
    It's piston based in the Rev D, not sure if a spring operates the piston or whether its simply electrically air controlled.
