Forge 007p Help
B1GW1L Sep 26, 2012
  1. B1GW1L
    B1GW1L Member
    96
    Hey Guys
    Just got my 007p delivered (thanks to DPM) just wanted to know what spring i should run and if i should use any plates?
    Currently running 255 BHP on an s3 Bam
    Thanks in advance
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Yellow for stage 1, green for standard so sounds like yellow will be fine.
  3. B1GW1L
    B1GW1L Member
    96
    Cool and what about the plates leave them out?
  4. Vex182
    1,035
    79
    Does not need any extra tension on the spring, usually stage 2 and above will require more tension on the spring.
  5. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Yellow spring for stage 1.
    If you've got stage 2 AND a Forge actuator then yellow and a shim, otherwise I'd stick with yellow personally.
  6. B1GW1L
    B1GW1L Member
    96
    Okay Guys thanks for the advice
  7. B1GW1L
    B1GW1L Member
    96
    Well I've fitted it and all is good thanks again for your help
  8. Vex182
    1,035
    79
    That's alright, what we are all here for!
