for those with no MAP boost sensor
freegeek Oct 28, 2009
  1. freegeek
    freegeek Member
    163
    I finally got round to doing a software release to support AGU engines.
    I calculate the boost pressure this way, boost = ((MAF x 53.5)/RPM) - 1
    It seems to be pretty accurate when tested on my BAM engine comparing the real MAP with the calculated values.
    The pictures below show two similar 4th gear runs from off throttle at 40mph the WOT for about 4 or 5 seconds, the top picture is a plot of the calculated boost, the picture below is an almost identical run showing the actual bost.
    Using the calculated method gives addition vaccum information not available from the MAP sensor as it is before the throttle plate.
    The video below shows it in use using the "agu calculated metod".
  2. <tuffty/>
    21,135
    3,825
    ooooooooooooooooo... :D
    Looks good Jim...
  3. aragorn
    18,293
    802
    Is that "pressure" absolute?
    1.4bar seems pretty high unless its absolute pressure, in which case it should be called "manifold pressure" rather than "boost pressure"?
  4. Lee Goodall
    Lee Goodall Active Member
    2,279
    How much are we looking at for the B5 vent mounted version?
    Aragorn- 1.4bar is not even nearly enough boost ;)
  5. aragorn
    18,293
    802
    well i guess its maybe not a stock car, but its what 20psi?
    Sounds high to me, but maybe its a normal figure for a BAM with a remap?
  6. Lee Goodall
    2,279
    1.4 BAR - 20.30532 PSI
  7. aragorn
    18,293
    802
    Ye, and a standard car runs about 0.5 bar hence the question.
    In vagcom it shows absolute pressure, so 0.5bar of boost shows as 1500 milibar manifold pressure.
  8. Lee Goodall
    2,279
    Watching the video I'm guessing that it's not a tuned/mapped car so it must be absolute pressure?
  9. freegeek
    freegeek Member
    163
    The video is my mapped 270bhp TT, showing boost pressure.
  10. Lee Goodall
    2,279
    Makes sense.. Looks good then :icon_thumright:
    What price are we looking at?
  11. freegeek
    freegeek Member
    163
    Hi the price will be £210 in a B5 vent but less if anyone gets a group buy going.
  12. Foxmeister
    Foxmeister Fired Up!
    1,785
    Group buy sounds good then. How much discount is on offer?
  13. freegeek
    freegeek Member
    163
    There was a group buy thread over in the A3 section somewhere.
