For Sunroof Owners
Ekkie Jun 23, 2007
  1. Ekkie
    Ekkie New Member
    Guys,
    When sunroof is opened and all windows closed im experiancing winf noise in the cabin. When opeing a window a little this stops. The wind deteror on the sunroof seems to be fine. Have any of you experienced this and what is the solution?
    Ek
  2. SteveTDCi
    SteveTDCi Active Member
    1,407
    Its not different to my GOlf, I have the same problem.
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Same here I think, Ill check when it stops bloody raining!!
  4. Macduff
    Macduff Member
    742
    Is it like a pulsing that affects your eardrums quite a bit? If so I've never had a sunroof equipped car that didn't do it.
    Haven't had a sunroof for years now simply because of that.
  5. Ekkie
    Ekkie New Member
    Correct like that pulsing effect - i guess you just have to have another window slighty open to have the sunroof open...
  6. SteveTDCi
    1,407
    Its just an air pressure build up. With the Golf the roof opens to a position where buffeting is minimal, or you can make it open completly. The faster you go the more it hurts your ears. The A4's i've been looking at don't have them so i'm thinking of having one retro fitted at a later date
  7. Les 51
    Les 51 A pint of Diesel please!
    687
    It's because the vents in the boot (if they're in the boot on an Audi) are not opening enough. on my Mondeo I took the covers off them and that helps, if you have a look at them you may find you can prop them open to relieve the pressure.
  8. mrw_y2k
    mrw_y2k New Member
    You've just answered your own question :icon_thumright:
    Used to happen in my Golf with the sunroof open. Open a rear window a few mm, problem solved.
  9. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    This happens in every car, even an old Sierra I had used to do it.
  10. mrw_y2k
    mrw_y2k New Member
    I remember a couple of guys on the uk-mkivs.net forum posting about sunrooves and rear windows blowing out, bit extreme but that was somehow linked to pressure build-up.
    So, probably best to go for the open window solution......
  11. stoakseya4
    stoakseya4 Active Member
    1,221
    It starts (on mine) from about 35mph, through to about 50-55mph, then stops.
    Therefore the trick is never drop below 55mph !
  12. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    845
    Or dont have the roof open, just tilt it & then there is no problem! Well thats what I do anyway!
