footwell lights stopped working
bluequattro May 5, 2012
  1. bluequattro
    bluequattro Member
    411
    hey guys, i have some issues with my 05 a3, my footwell lights have stopped working, these were fitted a couple of years ago, bought from robin a3, parts were good quality and were virtually plug and play when fitting, however there not working anymore, i have checked the bulbs and wiring which all seems good, in vcds there is a tick in the box for footwell lights fitted, i have read everything i can on here to try fix this but cant find a solution, vcds is also telling me that my heated seating isnt enabled which is strange coz the seats seem to be working ok, i would really appreciate any help or clues on these problems guys, i have included a scan log of my car .
    cal
    Thursday,03,May,2012,12:18:26:40122
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 76 77
    7D
    VIN: WAUZZZ8P76A008244 Mileage: 61340km/38114miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 BA HW: 028 101 184 7
    Component: R4 2,0L EDC 0000SG 9882
    Revision: 12345678 Serial number: AUX7Z0E4FNJ0EW
    Coding: 0000172
    Shop #: WSC 66565 257 00032
    VCID: 63CED47DA24E991
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 R HW: 1K0 907 379 R
    Component: ESP 4MOTION MK60 0102
    Revision: 00T12001
    Coding: 0023170
    Shop #: WSC 06314 000 00000
    VCID: 41823EF51892EB1
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 J HW: 8P0 820 043 J
    Component: KlimavollautomatH15 0200
    Revision: 057817 Serial number: 8P0820043J
    VCID: 336E643D522E491
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Revision: 00H36000 Serial number: 00000001901924
    Coding: A18ADB26A214100000000000000000000008FE175C0200
    Shop #: WSC 06314 123 08192
    VCID: 40843BF11398E29
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    5 Faults Found:
    00156 - Control Circuit for Windshield Washer Pump
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:13:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    02398 - Control Circuit for Rear Windshield Washer Pump
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:13:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    02092 - Enabling Heated Seat
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:13:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    00897 - Windshield Washer Pump (V5)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:14:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    02091 - Rear Window Washer Pump (V13)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:14:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Revision: 91H1135 Serial number: 0037W0002GX7
    Coding: 0071612
    Shop #: WSC 06435 000 00000
    VCID: 479620ED36B6D51
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    Shop #: WSC 12345 123 12345
    Part No: XXXXXXXXXXX
    Component: E0221 H07 0090
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 BX HW: 8P0 920 981 BX
    Component: KOMBIINSTR. VDO H80 0460
    Revision: D08 Serial number: 2253ID08000155
    Coding: 0005414
    Shop #: WSC 02327 210 01865
    VCID: 8F2648CD9E46CD1
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001055188386
    Coding: FD0F0FCA070101
    Shop #: WSC 00847 210 80521
    VCID: 285483519BE83A9
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 A
    Component: HALDEX 4Motion 0105
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 2B5E7C5D8A1E111
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D08 Serial number: AUX7Z0E4FNJ0EW
    Shop #: WSC 00752 210 91076
    Address 37: Navigation Labels: None
    Part No SW: 4P0 035 192 Q HW: 4P0 035 192 Q
    Component: RNS-E HIGH EU H74 0660
    Revision: 05S Serial number: AUZBZ7H0917674
    Coding: 0205715
    Shop #: WSC 61379 150 12711
    VCID: 397256157042B31
    2 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:11:14
    Freeze Frame:
    Mileage: 61340 km
    Count: 2904
    Clock: 12:10
    00850 - Control Output Active; Radio Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:11:14
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0050
    Coding: 0000632
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 188000403F3F8D0D489AC63300
    Shop #: WSC 00853 210 60571
    VCID: F9F21615B0C2F31
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001242684
    VCID: F0E42B31E3B8B29
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000632
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 C
    Component: Dynamische LWR H01 0010
    Revision: 00000000 Serial number:
    Coding: 0000002
    VCID: 3A7049197544B89
    Address 56: Radio Labels: None
    Coding: 0205715
    2 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:11:14
    Freeze Frame:
    Mileage: 61340 km
    Count: 2904
    Clock: 12:10
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 61341 km
    Time Indication: 0
    Date: 2012.04.29
    Time: 12:11:14
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0010
    Revision: 00H09000 Serial number: 00067824820513
    Coding: 0000003
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
    Component: FSE_255x BT H21 0290
    Revision: 00000001 Serial number: 00000000444265
    Coding: 0011402
    VCID: 3B7E4C1D7A7E811
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D5A7245B40A1F1
    End ---------------------------------------------------------------------
  2. bluequattro
    bluequattro Member
    411
    wee bump for the vcds wizards out there :)
    cal
  3. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,056
    757
    Check the earting is still ok.
    also pull out the socket wher you have pluged live as this could of pushed its self away. unplug and plug back in.
    Trups
  4. bluequattro
    bluequattro Member
    411
    Il try your suggestions tomorrow matey, and will let you
    know if im succesful :)
    Cal
