Footwell lights.... I want them
rob irl tdi Oct 9, 2011
  1. rob irl tdi
    rob irl tdi Member
    240
    Are they hard to do? I would like to do them and the puddle lights if possible.
    My sport just has reflectors in door so not sure if the puddle lights can be done. But I'd really like to do the footwell lights if I can.
    I've done my cruise, r-nse and DIS retro with no probs
    I'm listening
  2. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    OEM Footwell lights here.
  3. rob irl tdi
    rob irl tdi Member
    240
    Am I right in saying that some of the convenience modules don't support the footwell lights?
  4. swarcup
    swarcup Well-Known Member
    1,326
    40
    i wired them from my interior light, i know its not the accepted way but i wanted them all to come on when 1 door was opened as far as i know only the relevant one comes on when coded properly
  5. rob irl tdi
    rob irl tdi Member
    240
    You can wire it that way in the convenice module so they all come on when one door is open from what I read
    I might do it that way
  6. rob irl tdi
    rob irl tdi Member
    240
    Just want clarity on it in case I do it the OEM way
  7. alpesh26
    alpesh26 Active Member TeamMisano
    424
    45
    Swarcup, i'm thinking of going down this route too. Did you take the feed from the courtesy lamps in the roof and run the wires down the A pillar? Also, how did you get the wires to the seats (for the rear footwells) without any wires showing?
  8. Woorlord
    951
    17
    The Convenience module has various versions based on remote key fob radio frequency and inclusion/exclusion of vehicle alarm functionality & immobiliser aspects according to ETKA.
    There is no reference that I can see to the "light package" compatibility, so this would suggest they are all compatible for retrofitting footwell lights - subject to module coding as indicated in my install thread previously linked in Post#2.
  9. swarcup
    1,326
    40
    sorry i only did the fronts but exactly as you described
  10. rob irl tdi
    rob irl tdi Member
    240
    So can you tell me what type/size of wire I need in Maplins and what tools I need to get in there.
  11. quattrojames
    14,050
    578
  12. Woorlord
    951
    17
    Asked on compatibility again of Convenience Modules with Footwell lights.... should share this with you all>>>>
    Text description on how I fitted footwell lights to my "AJ" Convenience module (originally AH) is previously documented on this site - early days so not many pictures.
    I go by what I said previously, convenience modules are different with respect to alarm and keyfob transmitter frequency requirements of different countries.
    When looking in ETKA for variances in Convenience Module types there is no mention of Rear Electric Windows or Mechanical Rear Windows in the "model" field, the only reference is to keyfob frequency and alarm function.
    Rear Electric Windows in a Convenience module is simply an "adaption" option in channel 61.
    In fact the Ross-Tech site gives a PR code of "4R5" which relates to having manual rear windows and this is not mentioned in ETKA against any of the convenience modules.
    We do have 5D1, 5D2, 5D3, 5D4, 7AA, 7AL against various Conv Modules which means:
    5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
    5D2 = Carrier frequency 315 MHz
    5D3 = Carrier frequency 315 MHz with reduced transmitting power
    5D4 = Carrier frequency 315 MHz without panic button
    7AA = Electronic vehicle immobilization device
    7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection
    And for reference 4R5 means:
    4R5 = Power windows with comfort operation andcircuit breaker, mechanical window regulators rear​
    There is also no mention in ETKA against the Conv Module variances with regard to QQ1 which indicates Footwell lights and other interior lighting options.
    QQ1 = With additional lights (interior lighting)
    As a check make sure that there are pins in the footwell light connector "II" of your convenience module.
    <<OR>>
    If you also code your convenience module to fool it into having footwell lights now, you should get various errors of "open Circuit" against the footwell light you energise by opening a door. I recall having these errors prior to fitting the fuse to power the footwell lights.
    Some other VAG cars (Skoda/Seat/VW) may not have footwell light compatibility in their respective vehicle convenience module units and this may be where the compatibility confusion has arisen?
    Hope this helps.
  13. alpesh26
    424
    45
    Can you remember which wires you tapped into? I took the courtesy lamp unit out and found a loom with a longish connector going into it with about 8 or 10 wires. I tried to find wires going to the lamp holders but its got copper tracks instead :search:
  14. swarcup
    1,326
    40
    extract from woorlords thread at top of page
    Footwell Lights "ON" with Interior light:
    Based on the Interior Light connector and if you want the footwell lights to come on with the interior light then use Pin 3 (red/yellow) and Pin 10 (red/white) - these connections are effectively across the Interior light bulbs of the roof light, so run these wires to all your footwell lights in parallel.
    i can vouch it works a treat
  15. alpesh26
    424
    45
    Duh! I read this the other week! Cheers mate!
  16. Def-87
    Def-87 B7 2.0 TFSI Quattro
    46
    Trying to wire up my led strips to interior lights as you have instructed above. Connect pin 3 and 10 to leds.
    When the interior lights go out the led strips stay on constantly.
    Any ideas?
  17. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    I would get a multimeter on your connections
