foolishly cut the plug off my ctek battery charger
andymartin045 May 21, 2013
  1. andymartin045
    andymartin045 Member
    47
    Hello, I recently bought a ctek mxs 5.0 car battery charger, it came with a two prong plug. this didn't fit in my outdoor weatherproof socket (which only works when closed) as the plug stuck out too far. So I very foolishly cut the plug off thinking I could simply put on a UK 3 pin plug, unfortunately upon closer inspection-after the the deed was done-the ctek plug was fused at 16a and the highest fuse/plug that I can find is 13a. So now I have a £50 charger with no plug. Could you please advise how I best correct this, thanks, in advance, andy
    P.S. as you can tell by my above tale of woe, i'm a complete electrical novice so feel free to, if you are kind enough to answer, to put it into laymans terms.
    TECHNICAL SPECIFICATIONS
    Charger model MXS 5.0
    Model number 1049
    Rated Voltage AC 220–240V AC, 50–60Hz
    Charging voltage 14.4V, 14.7V, 15.8V
    Min battery voltage 2.0V
    Charging current 5A max
    Current, mains 0.65A rms (at full charging current)
    Back current drain* <1Ah/month
    Ripple** <4%
    Battery capacity 1.2―110Ah up to 160Ah for maintenance
  2. Chillout
    Chillout Active Member
    607
    I would just fit a standard 13 amp 3 pin plug and if it blows the 13 amp fuse i can't see it causing a problems as if it was plugged into an extension lead it would only be fused at 13 amp worst case the fuse blows but no one is in any danger.
