Folding Mirrors
stevey_cam Nov 27, 2012
  1. stevey_cam
    stevey_cam Member
    84
    Do the electric folding mirrors fold with the remote locking or is it using the mirror controls inside?
  2. Vertigo1
    Vertigo1 Well-Known Member
    3,668
    748
    Both. You can use the switch to fold them manually or you can set them to fold automatically. If on auto then they fold when you lock the car and unfold when you start the ignition.
  3. stevey_cam
    stevey_cam Member
    84
    Nice! Think I'll need to add them on to my order.
    Are the options set in the MMI?
  4. Vertigo1
    3,668
    748
    Yep :)
  5. stevey_cam
    stevey_cam Member
    84
    Just had a reply back from the dealer and my spec is locked for production now so can't make any changes :(
  6. NHN
    29,523
    1,766
    Can retrofit later mate, unfortunately at more cost, but can be done, wing me a PM if you cant sway dealer, just did same for an RS3 dealer cocked up order on.
  7. stevey_cam
    stevey_cam Member
    84
    Thanks I'll keep that in mind. It's not something I'm to worried about though.
  8. suzannec
    suzannec Member
    118
    10
    Veritgo - How do you set that up? (Auto)
  9. Vertigo1
    3,668
    748
    It's in the MMI car settings menu somewhere - can't remember off the top of my head but can have a look for you if you like? :)
  10. suzannec
    suzannec Member
    118
    10
    I will wait until I get the car (tomorrow) and take a look, I'm sure I can set it up now I know it is possible! I'll be sure to ask if I get stuck! ;)
  11. number3
    number3 Active Member
    335
    27
    does the auto dip on reversing only work with the electric folding mirrors? manual wasnt clear?
  12. NHN
    29,523
    1,766
    The folding just does exactly that, the 4 way movement is a seperate feed altogether.
  13. number3
    335
    27
    So along with electric folding, the auto dip when reverising is a seperate option? or standard?
  14. NHN
    29,523
    1,766
    The folding is seperate from the mirror movement, so effectively its possible on non folding, but you'd have to check if the dipping is only possible on memory mirrors or on standard 4 way electrics with no memory feature.
    It may also be a case of the reversing relies on mirror part that only comes with the folding mechanics anyway, so there's a few variables to check as audi arent that kind at times.
  15. Vertigo1
    3,668
    748
    The brochure only mentions the kerb dipping function as part of the folding mirrors option so I guess you don't get it otherwise.
  16. stevey_cam
    stevey_cam Member
    84
    Possibly something that will be possible to activate with vcds?
  17. NHN
    29,523
    1,766
    I was about to say that lol, but yes you need to research mirror types to see if it relies on sensors within mirrors or just a timing based dipping system.
  18. Vertigo1
    3,668
    748
    It's triggered by the position of the window switch and whether you're in reverse gear, so nothing in the mirror itself. Don't see any technical reason why it couldn't work without folding mirrors as all it needs in the mirror assembly is the standard adjustment motor.
  19. NHN
    29,523
    1,766
    Well yes the reverse gear was an obvious requirement lol, but of course the mirror needs 4 way to be able to utilise the system in the 1st place, but to return it to the position before, it must use 1 system to know previous position as such, either microswitch/sensor based location or it has a timer based circuit, possibly a combo of both.
