Fogs to match DRL
aadams1x Nov 6, 2011
  1. aadams1x
    aadams1x Member
    69
    Hi, When using the coming home feature on my car when the fog lights are on and the DRL the fogs are so yellow in comparison, what is the best recommendation for replacement fog lights that will get close to the white lights on the DRL's?
    Thanks for your help :)
  2. grimp
    grimp Member
    142
    14
    What year is your car?
    if ur thinking about the my09+, ive tried LOTS of different bulbs and ive come to the conclusion that GP Thunder 7500k is the best:
    Paullie likes this.
  3. slade777
    slade777 Member
    763
    They do look good or you could get LEDs from Trups "t8ups" on here few people have done this and they look awesome! Look for Silkys thread
  4. nally
    nally MPG the new BPH
    2,104
    34
    i want my fogs to still work where can i get these bulbs ( the leds wont cut through fog will they ?)
  5. grimp
    grimp Member
    142
    14
    ebay
  6. nally
    2,104
    34
  7. slade777
    slade777 Member
    763
    I understand what your saying however I've found when either xenons or even the sidelights (LED DRLs) the fogs are pathetic and don't do anything in the fog. If you really need fog lights low yellow light is the best!
  8. grimp
    grimp Member
    142
    14
  9. nally
    2,104
    34
    hmmmmm didnt know bowt the yellow thing think i am still gonna get them they should work better than the standard ones surly
  10. nally
    2,104
    34
    thank you
  11. Cartéen
    Cartéen New Member
    9
    GRIMP: Looks realy good on your car. Thinking of uppgrade my fogs to Philips Diamond Vision 5000k but when i saw your GP Thunders i migtht rethink. Have you also tried Philips Diamond Vision 5000k?
  12. grimp
    grimp Member
    142
    14
    No i haven't, but 5000k? sounds pretty yellow to me..
  13. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    How about HID 6000k (H11) on the fog lights ?
  14. grimp
    grimp Member
    142
    14
    Maybe, personally i don't care for aftermarket HID'S..
  15. J.R.
    1,405
    68
  16. dzTT
    dzTT Active Member
    333
    29
    Im quite interested in changing the yellow fogs to something a bit better, the past few days the visability has been 50 yards at best but usually around 10. and since switching the fogs on the yellow light just dosnt look right. Are they easy enough to get out and swap over?
    Not had a chance to look, only just looked under the hood last night after having the car 2 months :whistle2:
    Dazz
  17. slade777
    slade777 Member
    763
    Yellow light is by far the best for Practicality. Many people have been changing for Blue bulbs for pure aesthetics not actual visibility in foggy conditions. I personally find with xenons or even side lights which are LEDs the fogs can't be seen anyway.
  18. nally
    2,104
    34
    thats a proper catch 22
  19. slade777
    slade777 Member
    763
    Indeed but I'm personally going or LED fogs to match my DRLs and turning them down to about 40% ie not blinding for others. (running them as DRLs)
  20. nally
    2,104
    34
    sounds to complicated :uhm:
  21. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    570
    154
    43
    Hi which LED option did you go for for the H11 fogs? Do they produce as much light?
    I rarely use the fogs as a pair but have the cornering function active so brighter white the better in this case.
  22. slade777
    slade777 Member
    763
    I got H11 LED fogs from Trups (t8ups) on here. I haven't got round to fitting them yet as need to mount the resistors which get very hot. There are a few thread which show some pics somewhere
  23. Helifella
    570
    154
    43
    Ok mate cheers, thanks for both replies.
  24. MattyW19
    MattyW19 Member
    401
    Are the GP Thunder 7500k road legal? I've fitted Xenon Ring to mine and they are just a slight tad yellower than the xenons - A massive improvement from the original ones!
  25. NME
    NME Member
    150
    19
    Its not a legal requirement to have to have front fog lights, so as long as they are not ridiculously bright and burning peoples retinas out of their skulls, you should be ok!
