Fog lights as DRL?
Pricy Jun 20, 2011
  1. Pricy
    Pricy Member Team V6 quattro Audi A4 Audi Avant Owner Group S-line owners group TDi
    99
    19
    Hi guys, just been looking at the VCDS changes thread and came across Byte 17 Bit 4.
    Now I have a 2007 8P which im thinking of fitting fog lights to. Once I've fitted the fogs would I then be able to go into VCDS and enable the fog lights as DRLs or is this function only for newer 8Ps that came with DRLs as standard?
  2. Ash187
    7,443
    704
    I have this option on my 2005 A3 and it does work. You can turn on the North american DRL and that will have your headlights on all the time with no rear tail lights on. With the option for fogs as DRL it will only have the fogs on all the time. Just keep in mind that it is illegal to drive around all day with your fogs on, and that may result in you getting a fine and even points on your license!
  3. matt_hilluk
    matt_hilluk facebook.com/m9tbh
    255
    17
    I did think that it was an offence. Yet so many people do it. I don't know in which country they would want/need to have fog lights permanently on?
    I have seen on some A3's though, where the fog lamps should be replaces with a strip of LEDS for DRLS.
  4. Ash187
    7,443
    704
    i have personally been pulled over and fined £30 for 'misuse of optional lights'
    honestly the to$$ers have nothing better to do!
  5. matt_hilluk
    255
    17
  6. Pricy
    99
    19
    I think I'll leave it if it could mean me getting a fine! Although I might try the north american setting as Ash says, I presume I don't need a new headlight switch with the "DRL" setting on it?
  7. Ash187
    7,443
    704
    with the north american setting on it will leave the headlights on all the time the engine is on. as for the DRL switch i am pretty sure (dont quote me) that the switch would need to be wired in somewhere for it to actually be able to turn the drl(headlights) off. The switch is not needed but i can see it as being handy
  8. Pricy
    99
    19
    Thanks Ash, that's what I thought, I'll give it a go when I get my hands on VCDS and see what happens.
  9. Ash187
    7,443
    704
    no probs mate... where abouts are you? there are loads of members that have the cable that can do this for you
  10. Pricy
    99
    19
    I'm up in Doncaster mate, think I've got someone who I can borrow a laptop and cable off of for a few hours though so I'm going to have a little play when I get round to it. Got a list of things I want to activate/deactivate!!
  11. Rhyso
    Rhyso Well-Known Member
    1,392
    273
    I've just enabled fogs as DRL's on my car; (57 plate SB)
    You can adjust the brightness of them too :) Have set it to approx 25% If you have the extended menus within the DIS you can switch them off. Also they switch off when you turn on your sidelights or dipped beam. Bonus is they also work as normal fogs too :)
  12. danb986
    danb986 In awe of VCDS Team Daytona
    518
    58
    I need to try this now. I didn't realise you could turn the brightness down a bit!
  13. Rhyso
    1,392
    273
    Yep scroll along the bytes within the long coder and you'll see an option along the lines of fog light dimming??? Its about the 15th box along? Got 5C in it IIRC. I think its set at 92. i changed it to 25
    When you switch them on as normal fogs, normal brightness is restored!
  14. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    304
    as we found out yesturday eh rhys lol
  15. Rhyso
    1,392
    273
    Yep! Much easier if you have people standing in front of the car whilst you tinker with the settings; saves you getting out of the car to go have a look lol
  16. audicruiser
    audicruiser Audi Heaven
    1,865
    Are they equal now?? :huh:
  17. Rhyso
    1,392
    273
    I looked at them this evening and the photos I took and they look even :unsure: I've got some new fog light tint coming with the headlight tint so I'll replace what's currently fitted. I even checked that the bulbs were located correctly and they are......
  18. FranA3
    7,216
    304
    tis true mate
  19. audicruiser
    1,865
    Weird as there is no reason for them to be different. Maybe the film you have fitted now throws the light differently on one side?? Who knows... Looked cool tho :)
  20. Rhyso
    1,392
    273
    That was my thought; that perhaps one side isn't fitted quite properly so more light is escaping; although when they are acting as normal fogs the light output looks the same both sides.....oh well I'll leave them as they are and annoy everyone haha
  21. FranA3
    7,216
    304
    i really like fog light drl's i saw a new passat today with them and it looked really cool
  22. danb986
    518
    58
    I had one fog a lot brighter than the other and it just needed adjusting. Using the big Allen key screw I just turned it until the lights shining on my garage door were the same height and all looks right again. On mine it was more a case of height adjustment rather than actually being brighter.
    When you say you can turn them off in the extended menus in the DIS, is this only on the white LED models, or can you do it with the red DIS's as well? Mine's an 07 Sportback Sport, and I don't think I have the extended menu's, just the 2 trip computer screens, the digital speedo and the one with oil temp and service countdown screen.
  23. Rhyso
    1,392
    273
    Ah I removed my drivers side the other day so perhaps a slight adjustment is needed; thanks for that! Thought I was going mad lol
    I have enabled it on my 57 plate SB with RED DIS (pics in my build thread); I think 57 plates' on had the later CE module installed; all the 07 plate cars and prior I have not been able to enable the extended menus
