Fog light missing?!
Jp-tqs Dec 7, 2010
  1. Jp-tqs
    Jp-tqs Member
    183
    Checking my bulbs were all working as you do, and found i only had one rear fog light on, drivers side. Had a look and no bulb there! Got a bulb, fitted it, then it made my indicators come on and blink with the fog lights?!?! Eh? Has anyone got a reason for this? Ta!
  2. aragorn
    18,129
    763
    UK cars only have one foglight as standard.
    If its an avant i've found the contact is there, but the hole in the lens isnt, so its a case of slotting the bulb into the holder, and then breaking a hole in the back of the light cluster.
    Craigs S4 (saloon) however didnt actually have the contacts in the bulb holder, so fitting a bulb did nothing.
  3. PaulTheo
    PaulTheo Member
    126
    My B5 saloon also had the bulb holder and working contacts but no hole in the lens unit. I just machined out a hole and it worked perfectly.
  4. Jp-tqs
    Jp-tqs Member
    183
    Well, im still confused! When i put the extra fog light in (passenger side) i had engine running, headlights and fog lights ( front and back) on. Soon as i put the extra rear fog light in the indicator came on?!
  5. Oranoco
    Oranoco Well-Known Member
    3,859
    381
    You need facelift bulb holders as these have the contact then simply Dremmel the lamp unit and et voila twin rear fogs
  6. Jp-tqs
    Jp-tqs Member
    183
    Ok, my car is facelift anyway! Ill try again tommorow and make sure im not being a retard! All i want is twin rear fogs!
  7. NineNails
    NineNails Proud sponsor of the snack food industry
    591
    I was driving in fog the other day and tbh I don't like being behind cars with 2 rear fogs. It sometimes makes me think they are brake lights and sre generally just annoying...
